Dropping 12vAC down to 9vAC
LaceSensor
Has thanked: 57 times
Been thanked: 277 times
Post by LaceSensor »
Hi
Anyone know of a simple method to drop AC from 12v down to 9v?
I have a new PSU that outputs 12vAC from one of the slots, but I need 9vAC.
I searched and came up empty. Lots of threads about doubling up :)
thanks
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
LaceSensor wrote:Hi
thanks
You could try using a suitably rated 5 Watt Wirewound resistor, you only need to drop about 3V if my maths is right, how much current can your power supply put out?... :hmmm:
LaceSensor
~The AC power outs are rated 250mA
Post by DrNomis »
LaceSensor wrote:~The AC power outs are rated 250mA
Okay, so you could probably use Ohm's Law to calculate what the value of the resistor should be:
E=Volts.
I=Current.
R=Resistance (in Ohms).
P=Power (in Watts).
So, we want to drop 3V across a resistor, current is .25A (250mA), in Ohm's Law R=E/I (Volts divided by Current).
Therefore :
R= 3V/.25A
= 12 Ohms
And 12 Ohm/5 Watt resistors are avalible, 5Watts should be more than adequate....hope that helps.... :thumbsup
P=I X V
P = .25A X 3V
= 0.75 Watts
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
Ah, but the outputs are UP TO 250mA; you need to know the actual DRAW of the pedal.
LaceSensor
Hey
Whats the best way to do this? Can a DMM be used?
Post by DrNomis »
Hides-His-Eyes wrote:Ah, but the outputs are UP TO 250mA; you need to know the actual DRAW of the pedal.
Good point Hides-His-Eyes.... :thumbsup
Hides-His-Eyes
LaceSensor wrote:Hey
yes! connect up the power supply using crocodile clips or similar and put your multimeter on "AC amps" setting somewhere in series along the power supply (e.g. between the battery and the circuit). Just make sure it's in SERIES.
That should give you the current draw, roughly.
