stereo valve amp question
Posted: 17 Jul 2011, 10:21
by 9 volt
Hello, I have an old single ended stereo valve amp (basic amp with 6wg8 valves). I noticed that the balance control is a pot that connects the cathodes (triodes) to ground. Cathode to 150ohm on each side of the pot and a 20uf on the middle lug going to ground. Anyone ever heard of this? I thought the balance would normally send the signal to ground......Thanks
Re: stereo valve amp question
Posted: 24 Jul 2011, 18:53
by JiM
9 volt wrote:I noticed that the balance control is a pot that connects the cathodes [...] to 150ohm on each side of the pot and a 20uf on the middle lug going to ground.
This looks like a variable cathode bypass cap.
There should be proper cathode resistor(s) to ground, and the pots brings a variable amount of decoupling cap, which increases gain (above a certain frequency, set by the cap value) without changing the DC bias. This should indeed be pretty effective as a balance control.
More info here : http://www.freewebs.com/valvewizard1/gainstage.html
Posted: 30 Aug 2011, 01:23
by 9 volt
Thanks Jim, this makes sense. Also thanks for the link, much appreciated!
