Bootleg - SPL-10 Spiral
- Chugs
- Nocentelli
- Has thanked: 1115 times
- Been thanked: 939 times
i'd love to see a trace of this: i like the idea of additional depth and colour pots on a smallstone....
- Nocentelli
can you post a pic of the box? i can't find a single reference to this pedal on the net.
- rocklander
- Has thanked: 1404 times
- Been thanked: 227 times
- Contact:
indeed... also, does it suffer from the volume drop?Nocentelli wrote:i'd love to see a trace of this: i like the idea of additional depth and colour pots on a smallstone....
- Chugs
- Chugs
Actually, not sure if it is buffered bypass or not. I might be confusing it with another pedal. I was poking around the insides of several pedals yesterday and all the circuits are mixed up in my head!
- roseblood11
Retracing would be much easier, if you would post a better picture of the component side:
- exactly right-angled
- backlit with a very bright lamp so that the traces are visible
Reading the color codes just from the pictures is error-prone. Itś easier if you do that...
http://www.hobby-hour.com/electronics/r ... ulator.php
- Chugs
I tried a trick in photoshop, but the images aren't square enough and not enough natural light. If you can, retake the picture of the front in a good natural light, as square as possible.
I've had some luck taking the back side of the board, flipping it horizontally in photoshop, then takign the two images and superimposing them on themselves. Change the opacity of the top layer to like 70 percent. Then free transform > distort and line up the 4 corners of the two layers (front and back). The traces will line up and you'll have a sort of xray version with the traces appearing in the correct position on the top of the board. It works best if you have photoshop and can make a few layers with different opacities and flip between them. Inverting the color of the solder trace image will make the traces pop better.
Ouch, never seen it lock up a PC! Check your event viewer for things to look for.
You can see that the Image > Distort doesn't line everything up perfectly with images that aren't already close to square for the lens of the camera. I traced a board out this weekend using this method and it worked really well. Better if you have Photoshop and can change between images and opacities....
- culturejam
I like that they used OTAs for the all-pass filters but didn't use an OTA for the LFO. It's handy because all of the inexpensive OTAs are duals, so you end up with one left over if you use OTA for LFO. Of course, I'm assuming they have 4 phase shift stages and not 2.
I'll be watching this with interest.
- rocklander
- Contact:
I've not heard of this one... what's the story?Duckman wrote:And what happens about avoiding right angles when you draw a circuit?
It does'nt seem a problem for Boot-Leg designers. Why?
- Duckman
- Opamp Operator
rocklander wrote:I've not heard of this one... what's the story?Duckman wrote:And what happens about avoiding right angles when you draw a circuit?
Maybe I have misunderstood something ... That would not surprise me
