This topic might as well been in the Workbench subforum, but it's all about an amp. I detail the debugging process for further information, but my quetsion will come afterwards!
So a friend of mine brought his faulty RS700 head this morning. Symptoms are:
- the amp buzzes loudly when no instrument is plugged (even with no speaker on).
- one of the two heatsinks (the one for the P-channel mosfets) is getting really hot.
- when he plays the instrument, fuse blows at first note...
When power transistors are unplugged from the power supply, I get the +75/-75VDC ok.
When the power transistors are connected again, the 75VDC wire appears to be 0VDC on the N-channel side. And, of course, the -75V turns into -150VDC for the P-channel side...!!
So there's a short, obviously. Quick check of the 5 resistors, ceramics and mosfets brings out one N-channel with Drain and Source shorted.
All done!
Now, there are 5 mosfets in parallel, like in this picture below (Ampeg SVT4Pro): Do I need to match the new mosfet with the 4 others, or having these running in parallel is going to "compensate" the possible differences?
What parameter do I have to look at when matching?
Thanks for your help on this!
