I bought all the parts and soldered it all up, but then no sound! :O
After a bit of wiggling I managed to get a signal through, though severely weakened, and only when I move component in the right way.
I'm a bit of a novice I should mention to soldering, so I'm not sure if I burnt out some of the small caps with high heats?
When I wiggle the gain pot I sometimes get a loud, high pitched sound which increases in pitch and oscillates?
I have a few theories as to where I went wrong. Mainly they are to do with the parts I used for example:
I forgot to buy a 1N4001 Diode so I used an LED instead, Instead of a 51 pf cap I used a 56 pf,
And instead of the IC being a an 4049UBE I used a 4049BP? I'm also not sure if I put the electrolytic caps the right way.
I can post pictures if you like
Please help.
