Anyone ever used a Weber WPDLXFMR transformer?
bruin2k3
Has thanked: 25 times
Post by bruin2k3 »
I understand that it has 8 isolated 11V AC outputs and a 9V AC out. Have any of you used it before? Good results with it? Does it come with 20 leads and is each pair individually labeled?
-Bruin2k3
mysticwhiskey
Has thanked: 42 times
Been thanked: 175 times
Post by mysticwhiskey »
I've used the 240V version (WPDLXFMR-2), which seems to work fine. 300mA per AC output is plenty of power for most pedals. Each pair of secondary output wires have a unique colour, so they're easily identified.
bruin2k3 wrote:I understand that it has 8 isolated 11V AC outputs and a 9V AC out. Have any of you used it before? Good results with it? Does it come with 20 leads and is each pair individually labeled?
-Bruin2k3
MGW
Post by MGW »
The 120v version works great, but they aren't individually labelled. However, the pairs are all side by side coming out of the xformer. The 9VAC tap is green, the others are brown. Used one for about 18 months and went back to a rack recently. Worked great.
I built a supply with one and it works fine. Only beef I had with it is the pairs not being easily identified and that it's so large, it won't fit into any sort of compact box.
chicago_mike
Has thanked: 22 times
Been thanked: 316 times
Post by chicago_mike »
Reviving an old thread!!!! :horsey: :horsey:
I just got one in the mail.
The thing i need is a large enough enclosure... :scratch:
Went with the 120/240 model since the cruise ships have both.
Skyline FX 2013
PokeyPete
Been thanked: 43 times
Post by PokeyPete »
As I stated elsewhere in a similar topic, I used this for my power supply. However, as I recall the 240V version is a little too large for this box.
I mounted the xfmr in the center and had room on each side for 4 circuits. It's not a pretty box, but quite functional.
http://www.smallbearelec.com/servlet/Detail?no=698
–Hunter S. Thompson
