grrrunge wrote:We tested the bass through an off metal zone for the buffer, y cable into LPB and SD-1 and then their respective outputs into a DOD 240 passive mixer as we didn't have more y cables...
i'm similarly interested in this kind of scheme, as i'm planning a parallel trem+vibrato. from what i've read, some sort of input buffer/splitter circuit will do the trick, and you might get away with a simple passive mixer pot on the output, particularly if both circuits have an output level pot. i'd be inclined to make both boards, hook up the bass into the amz buffer/splitter muamp jobby, send two parallel output signals to the two boards, and wire the outputs of the two boards to lugs 1+3 of a linear pot, with lug 2 as the outpu: i'm guessing you could even just replicate this pot set at 50% with two 50k resistors on the ends of each output, and tie them as the output, as you said, the two volume controls should allow you to balance them. If there is any weird interaction, you might need to investigate an output mixer/buffer bloc.
