L'Overdrive de la Révolution Deux - A tribute to FS.org!
A small update:
I kicked out a rotten trimpot and got some better biasing on the LORD -- and of course the sound improved radically with tonecontrol engaged. I measured these voltages at 8,93V
Q1 = 2N7000
D = 6,65V
G = 3,26V
S = 1,36V
Q2 = 2N5457
D = 4,63V
S= 0,73V
G = 0V
Q3 = SK117
D = 5,50V
S= 0,13V
G = 0V
There really is dramatic headroom improvement when you feed the circuit more than 9V, but over 12V I hardly hear any improvement. I had the same with other jfet circuits like minibooster based designs. Some more pictures later....
will post some more observations on the layout in the etching thread.
But here's the file I used if anybody would like to use it (for a Hammond 1590BB) - did replace the toggle with a footswitch to control the gain boost that you get by cutting out the tone circuit. Check the measurements of your print and resize accordingly. I printed at 67% - this way you get better resolution on the fonts than working 1/1
L'ORD Etching mask
briggs
Has thanked: 27 times
Been thanked: 126 times
Post by briggs »
WOW! Now that is COOL! I've gotta start etching myself some boxes with the logo on 8) That really does look great.
How did you mount those LED's modman?
I am Klon.
briggs wrote:How did you mount those LED's modman?
With a 3mm drill bit :D , then sort of snap into place. But will be securing with some glue later on, they hold allright for now. LEDs are both mounted on Orman antipop circuits built on veroboard: here are some more visuals:
thanks
ps: jfet on their way :wink:
erikm5150
Post by erikm5150 »
Has anyone verified the vero yet?
I'm no expert, but it looks like the signal doesn't travel from Q2 to Q3, and R11 is in the wrong place.
Torchy
Post by Torchy »
Give that man a coconut !
R11 was the wrong side of the JFET - corrected below.
erikm5150
Post by erikm5150 »
Thanks for the coconut!
Also, shouldn't lug 3 of the gain pot connect to the bottom leg (source) of the mosfet, and also shouldn't C1 and R1 connect to the middle leg (gate)... just like in the box of rock...
i just built a BoR based on your vero (thanks! by the way), so it's still fresh in my mind...
Torchy
Post by Torchy »
I think I used a jfet instead of a mosfet when I built mine, so I may have used a DSG pinout - I'll check it over :oops:
Torchy
Post by Torchy »
So thats a pair of coconuts :mrgreen:
Redone. Again. Checks out ok to me now.
erikm5150
Post by erikm5150 »
Torchy wrote:So thats a pair of coconuts :mrgreen:
Cheers!
ech0es
Post by ech0es »
i"m french and i must tell you that the name of this pedal sounds a little bit strange in french.
gght
Has thanked: 47 times
Post by gght »
English translation, as you read it, please????
:hmmm:
gght
briggs
Post by briggs »
ech0es wrote:i"m french and i must tell you that the name of this pedal sounds a little bit strange in french.
Haha. I found the name on a website somewhere - something to do with the May '68 stuff that went on in France... My French skills are very, very poor!
I am Klon.
briggs
Post by briggs »
P.s I updated my blog with the correct layout. Cheers Torch..
I am Klon.
nihoneiga
my favorite amplifier: 63' Fender Bandmaster
Completed builds: Maestro MFZ-1 (my favorite), 1977 Big Muff, Fuzz Factory, EA Tremolo, Super Hard-on, ROG Tubescreamer
Post by nihoneiga »
So along with Modman I'm thinking to build this guy up with the gain boost switch as a foot switch but I'm kinda new to this and don't have confidence on how the gain boost switch would be wired in. According to the schematic there is a little asterisk by the tone section, would you just wire in a DPDT switch there that would allow bypass?
Also, on a different but equally newbie note, how do you measure the values of the transistors as you adjust the trim pots? Is there a general guideline to which way you turn the trims etc?
Look forward to having it up and screaming!
briggs
Post by briggs »
The tone stack is wired in to be bypassed as you say - the trim pots, you measure the voltage between the Jfet drain and the positive supply. Son't worry about which way to turn them, you won't cause damage by going the wrong way. It's a while since I came up with this - I remember is sounding a lot better at 18v. Good luck with your build - any other questions, post away 8)
I am Klon.
Ben N
Has thanked: 167 times
Been thanked: 50 times
Post by Ben N »
fertooos wrote:Such news is always very sad. But we all may provide great support to people in such a situation. I believe even a simple postcard can do a miracle when a person is living his last days https://areacodes.net/954. If all friends and acquaintances of a man send their attention, that can perform a miracle. We have to do kind things as it is the only way to make the world a bit kinder.
plush
Has thanked: 35 times
Been thanked: 160 times
Post by plush »
Ben N wrote: ??
It was bot. Quite advanced one.
