wiring dc jack
TimothyT
Post by TimothyT »
Hi guys, i just bought a dc jack and i'm not sure how to wire it, here is the pic of the dc jack
Learning in progress...
atreidesheir
Has thanked: 441 times
Been thanked: 43 times
Post by atreidesheir »
I had the same questions in the beginning. General Guitar Gadgets pdfs are very helpful with good visual examples.
http://www.generalguitargadgets.com/pdf ... wiring.pdf
Notice the jack wiring. it is pretty universal. Just locate ground and the rest is not.
BTW the dc jack image in your post is gone.
TimothyT
Post by TimothyT »
try this link https://i842.photobucket.com/albums/zz3 ... G_3707.jpg
https://i842.photobucket.com/albums/zz3 ... G_3719.jpg
hey thanks man, i had one of those dc jack but i realised the one i bought couldn't fit into my onespot powersupply. The one i had is made of metal, is it safe to use? i remember i read a post about using those dc jacks that is made of metal instead of the plastic one is not safe, how true is that?
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
The problem with metal dc jacks is not to do with safety, it's about the fact that Boss and most other manufacturers who use those 2.1mm jacks use the centre=negative convention. This makes the outer wire positive, and since metal jacks tend to have the metal casing and outer wire connected, the jack will short the +9v supply to ground if your metal enclosure is grounded (which it should be for radio frequency protection, and certainly will be if you are using standard metal frame jacks for audio input+output where the outer [ground] connection is almost always connected the metal frame of the socket).
I'd avoid using metal dc jacks for a guitar pedal unless I was certain it was an "isolated" jack, i.e. the outer (+9v) connection was insulated from the metal frame, or if I was using a plastic or otherwise non-conductive enclosure....
Have a look for threads on metal dc jacks, I'm sure more well-informed people have given better explanations elsewhere. The short version is - metal jacks good for 1/4" guitar jacks, plastic good for dc jacks.
TimothyT
Post by TimothyT »
i see.. thanks for providing such great info!
I have a typical effects pedal dc jack, but then the pin seems to be a little huge, can't be powered by 9v power supply.. sigh, gona do some more shopping in my local electronic shop :P
Nocentelli
I think 2.1mm is the standard pin size for all Boss and generic compatible power supplies, adaptors and daisychains: If you buy guitar-related products, it will be 2.1mm. However, in the wider electrical component world, t here is a 2.5mm slightly larger version that does not fit with standard pedals (i have but them inadvertantly before now), but they will look almost identical. Just check that whatever you use is a) 2.1mm and b) either plastic, or ISOLATED metal (if they even exist).
