I've tried a buttload of wiring schemes for the two footswitches, of which none worked. I had it working for the longest time, but I could only switch on the Soda Meiser only after the Torns Peaker switch was activated.
Thanks in advance!
Exactly, I'm just as stumped why it isn't working. Could it possibly be because that this has a shared ground?LaceSensor wrote:Have no idea but it seems teh vero has ins and outs for both effects so there is absolutely no reason why it wouldnt work.
Are you saying categorically, that you can wire up each effect seperately just fine? Then when you try to do them together it doesnt work?
