holding / mounting enclosure while painting
- theblackman
How do you guys hold your enclosure while painting while preventing touching of the paint before it dries?
How do you transfer the box into an oven for baking??
I have been putting the box on a tray and painting that way and then transferring to the oven but I can't reach the edge bits properly using this technique.
I have also tried suspending on a coat hanger but you alway end up with a mark where you hook the hanger in...
Any tips ??
Cheers, Richard.
Any tips ??
Cheers, Richard.
- CodeMonk
- Degoop Doctor
I usually put compatible screws in it (the ones for the cover), to raise it up.
Then CAREFULLY transfer to oven and slide it in.
I use a small pitchfork looking thing I made to lift and transfer.
Its kind of tricky though. I have dropped a few.
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
I use the plastic cap from the spraypaint can to support the enclosure and place them on an old computer case cover on my balcony, I start with at least two coats of etch-primer, then once that's dried I spray the enclosure with four coats of spray-paint of whichever colour I decide to use, leaving each coat to dry before applying the next, labelling is done with rub-on letraset, then I spray the labelling and the enclosure with 4 coats of clear satin acrylic, this method seems to work fine for me.....
- theblackman
Cool, I might try this!CodeMonk wrote:I usually put compatible screws in it (the ones for the cover), to raise it up.
I use toilet paper tubes. The more I can fit under it the better.
Haha, have like 100 of them hanging around now.
I also use latex gloves when handling a box from the time it goes on the TP tube stands until it leaves the oven and cools down.
- timbo_93631
- my favorite amplifier: Low wattage SE amps
- Completed builds: Many many many true bypass and voicing mods on wahs.
A few BYOC kits and DS-1 mods and eventual murder then rebirth into an actually useful pedal, Bad Stone clone, various Rangemasters/SilconMasterBlaster, The worlds greatest gutted GCB-95 volume pedal conversion with various switching options for controlling amps. Repaired many tube amps, scratchbuilt Marshall 18 watt clone and Supro 1616t rebuild. Delays, fuzz, dirt, every Madbean project I could afford. I even manage to find time to make babies with my wife too! - Location: Fresno, Ca
- Has thanked: 14 times
- Been thanked: 33 times
I paint the enclosure and the lid seperately, but at the same time, on two different stands adjacent to each other. For stands I use little rectangular plastic Gerber baby food containers, they are about 1.5" tall, 2.5" long, and 1.25" wide. A 1590B will even fit on one if I flip the container over. I let the paint dry for at least 45 minutes before moving. When I move the enclosure I pick it up by the baby food container and transfer it to my fingertips, only toching the inside of the enclosure, then I gently slide it onto the rack of my toaster oven. I bake at ~200 degrees F for 20 minutes every 2 coats.
"I wish to be in the situation of non killing my balls bills, and life surprises." -Sinner
"Everyone gets their shorts in a twist over who polished the fenders. No one cares about who designed the engine..." -DougH
