Subdecay - Gurgle and Moan Envelope Filter  [traced]
Brian M
my favorite amplifier: Vintage Twins
Been thanked: 54 times
Post by Brian M »
We made a few of these and sold them on ebay in late 2007. I remembered about it when reading another thread and OTA's came up.
I thought I'd let anyone who wants to take a look at it, build it, or do whatever with it.
download/file.php?id=25725&mode=view
I limited my self to a dual opamp, and the dual OTA because I wanted to fit it in a 1590B enclosure. Otherwise i probably would have used two more opamp stages rather than the Jfet input and especially the BJT output buffer... Or I could have just replaced the output buffer with an opamp, and used the other stage to make a reverse sweep function... lots of possibilitites, but only so much space to work with.
What the knobs do:
B100K in the upper middle left- resonance
B100K in the upper right- mix between LP and BP output
A100K range
B10K Center frequency
Known issues-
When the resonance pot is turned all the way up, it may oscillate. Perhaps adding a small resistor in series with the positive feedback would be a good idea here...
The mix pot is a bit scratchy, which should be pretty obvious. Not really loud scratchy, but if your amp is all the way up, you will notice it.
The decay is a but "gurgly" I actually kind of liked it that way with this perticular filter. Changing the 4.7uF cap to a 10uF would be more to some people's liking.
So there it is... a fairly simple envelope filter that doesnt rely on optoisolators, and sounds pretty good too.
The OTA circuit was basically lifted from the LM13700 data sheet, but I added the positive feedback for resonance.
Some known issues:
Reason: relinked schematic
prehistoric
Been thanked: 5 times
Post by prehistoric »
looks cool, brian.
i have a lot of respect for you guys with your low parts count circuits.
do you have soundclips?
hi Brian
thanks for sharing this with the World - hopefully one or more of the members here may build this and may even improve upon it :wink:
Once again - thanks for sharing it :D
Brian M
Post by Brian M »
bajaman wrote:hi Brian
Imrovements on filter circuits can be a lot of fun, and complex or as simple as you want to make them.
Taking the filter section as a building block, and coming up with different ways to create a control voltage could easilly create a number of cool projects.
This one is also probably could use some work... as noted above it was a bit compromised by the limitations I set my self up with.
A couple years ago I put a filter with 12 pots and a few switches on breadboard. It really was beyond overboard, because it would not have been all that user friendly. I tried to build a prototype, but after building the PCB with about 200 parts on it, it didnt work. I looked back at the artwork a few weeks later and realized i had merged two nets in to one, and couldnt make a fix very easilly. I still have the thing.... it's probably the most parts ive ever squeezed in to a stompbox... it looks impressive i guess :roll: would have been nice if it had worked.
Brian M
Post by Brian M »
prehistoric wrote:looks cool, brian.
Sorry, had to search the site for them... i couldnt find it last night.
http://subdecay.com/gurgle.mp3
It's kinda long, and after listening, you'll understand why it has gurgle in the name.
I'm not 100% sure that this clip was from the final schematic... I think it was still on breadboard when i recorded it.
prehistoric
great clip! the gurgling is a nice effect, and one not really commercially offered as it's own feature before as far is i know.
envelope filters are really nice. i like to bury them in the middle of a chain of fuzz/octavedown/loop etc so their effect is masked but still causing a harmonic blip in the chain, can make some demonic vowelly sounds
Brian M
Post by Brian M »
prehistoric wrote:great clip! the gurgling is a nice effect, and one not really commercially offered as it's own feature before as far is i know.
Actually, after listening to the clip again, I'm not sure how great it is. Seems more subtle than i remember.
Regardless, there is a pretty useful building block in between all the compromises noted above.
When i had this on breadboard, i also tried an LFO controlled dual filter with opposite sweeps. sort of a take on the anderton antiwah. Sounded pretty good, although it was a bit of a large circuit for what it actually did.
Im more of a filter after fuzz kind of guy though... That reminds me i need to get back to an old idea i had a couple years ago.... :D
Brian M
Post by Brian M »
Hmmm i was just looking at this schematic, and noticed that the envelope follower section was screwed up.
One of the resistors is not marked with a value. I'll post a corrected drawing soon.
briggs
Has thanked: 27 times
Been thanked: 126 times
Post by briggs »
The sound sample sounds pretty unique. I like it! Looking forward to seeing the updated scheme.
I am Klon.
Brian M
Post by Brian M »
fixed version posted. :)
have fun with it
mhond
Post by mhond »
the links are broken.. could someone be so kind to relink it :) im really curious !!
THNKS!!!!!
Brian M
Post by Brian M »
mhond wrote:the links are broken.. could someone be so kind to relink it :) im really curious !!
THNKS!!!!!
It got blasted when we restructured our website last year.
pedalgrinder
my favorite amplifier: Ampeg SVT
Completed builds: pedals with pots switches and everything
Has thanked: 198 times
Been thanked: 169 times
Post by pedalgrinder »
has anyone got a copy they could send me pm me if you do or repost it possibly cheers. thanks in advance :thumbsup
dauserarms
Post by dauserarms »
Sorry about digging up an old post but could some one repost the schematic?
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
rocklander wrote:
dauserarms wrote:Sorry about digging up an old post but could some one repost the schematic?
+1 ... schematic anywhere anyone?
Please note that Brian pulled this schematic:
Brian Subdecay wrote: A few notes-
This could be easily improved, as i made some minor compromises to fit it in to a 1590B case. In a perfect world the input and output buffers would be opamps.
the filter is essentially taken straight from the lm13700 datasheet, with positive feedback added for resonance, and values tweaked a bit for stompbox use.
We sold a few of these as prototypes as the gurgle and moan. it sounds good, but some tweaking could be done in the envelope follower to smooth things out a bit.
Sorry i don't have everything marked on here. I'll get to that some other time.
