Asbracy wrote:I recently joined this forum and performed the cap mod to the joyo ultimate octave. C9 and C15 rotate, worked for a bit and then no sound at all. A first it started cutting out and then stoped all together. I have experience soldering and electronics repair but lack a schematic for the circuit. Could it be a transistor? any help would be appreciated.
[Moderator note: edited the title]
hey asbracy, welsome to fsb. i hope you have a riot here.
drag about the joyo. i did this mod a few months ago after reading through this thread and following basshead's excellent instructions to the letter (i also posted follow up pics of mine in this same thread). it worked first time for me as it did for him.
https://www.freestompboxes.org/viewtopic ... 80#p243908
i'm no mastermind re troubleshooting but it would probably be worth reflowing your solder joints just to be sure you didn't get a dry one when you rotated them. hot and quick. a second. no lingering with the iron held to the board. as someone in the thread mentioned, if you dot your iron with a little bead of solder just before touching the cold solder you are trying to melt, the heat transfers quickly and it will melt almost on contact. reflowing will give your connection another chance to 'weld'.
if no change, did you replace or reuse the original caps? it could be that after being soldered in, soldered out, resoldered in, all that heating and cooling has got to one of them. perhaps try replacing them before going deeper into trouble-shooting (don't forget the negative stripe for orientation, pics of how they should look after the mod available in the thread).
that's what i would do. if no luck with that come back and we can go from there.
it may well be worth re-posting your help request in that original thread instead of continuing this new one. (a mod can perhaps insert this into that one).
the way this forum works is that when you look at your previous posts ('view your posts' in the menu bar) you can see if anyone has added anything new to posts you have contributed to.
a lot of members, myself included, check their previous posts link every visit.
anyone who contributed to that original joyo thread and was checking in like that would see your post immediately, but they might not notice it as an entirely new thread unless they were visiting every section of the forum.
so maybe repost your problem there if the ideas i have suggested above don't solve your problem.
good luck with it, asbracy. when you finally get it done you will be glad you persisted. it sounds amazing post-mod.
tabbycat.
