reel of guitar cable (where to buy)
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Hi all, i'm looking to buy a 100m reel of good guitar cable in the UK. Does anyone know of a good supplier ?
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
Ice-9 wrote:Hi all, i'm looking to buy a 100m reel of good guitar cable in the UK. Does anyone know of a good supplier ?
You could try your local Electronics Stores, I've had very good results with Balanced Mic cable, the one that has two inner cores and a shield, just solder the two inner cores together at each end, works a treat.... :thumbsup
marshmellow
Has thanked: 19 times
Been thanked: 126 times
Post by marshmellow »
Ice-9
Post by Ice-9 »
marshmellow wrote:http://www.canford.co.uk/
Ahh fantastic, i forgot about Canford audio, I live 20 minutes from them. :)
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
i just bought a 100M reel of guitar cable from musikding.de, and it seems really nice. Nice thick solid rubber coating on the outside, woven ground and double insulation between ground and signal... I have no idea about how it works out in the long run though, but i have high hopes on this account :)
Barcode
Been thanked: 32 times
Post by Barcode »
GLS is reasonable as well:
http://www.glsaudio.com/
EDIT: Nevermind, just noticed you said in the UK. I'm not batting a thousand today :)
