germanium diodes don't work in my BM..
Frequent question abouts LED and other types of diodes.
pietro_moog
Been thanked: 48 times
Post by pietro_moog »
hi guys. i built a big muff with a rotary switch for diodes. everything works ok except the germanium ones.
they just don't work, all of them.
i don't understand why.
if i measure them, they're good. but they don't work.
any idea?
asatbluesboy
Has thanked: 38 times
Post by asatbluesboy »
Wrong orientation? Bad solder joint? Bad karma? :D
...collectors together and emitter to base? You're such a darling...
ton.
.Mike
Been thanked: 31 times
Post by .Mike »
...damaged diodes during soldering? :?:
My website: America's Debate | My effects site: Just one more build...
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
It could be that you might have a dry solder joint or two somewhere, when you say "not working" do you mean that the diodes aren't clipping the signal?... :hmmm:
pietro_moog
i have a rotary switch system. 5 combinations, just the germanium one doesn't work, i re-did every connection- no cold joint.
i think the definitely answer is bad karma.
but what was the other one with damaged diodes during soldering?
.Mike
Post by .Mike »
Some people say germanium diodes can be heat sensitive during soldering.
I've never fried one, but gotta consider everything. :)
Mike
allesz
Has thanked: 41 times
Been thanked: 96 times
Post by allesz »
Just a quick test: disconnect the rotary switch, conect a fresh couple of diodes to the circuit with some alligator clips and see if they work.
