How do I put a cab sim between the amp and cabinet?
- jimosity
OK - So I have a cabinet simulator circuit.
Say I want to have it run between the amp and the cabinet.
I'd run from the head out to the input of the cab sim, then a thru put that feeds the speaker cabinet and also tap off the input to send to the input of the cab sim circuit and then the output of the cab sim would run into a mixer/recordingunit/etc.
I know I've used a RedBox in the past to do something similar, but I don't want to use a redbox now and would rather figure out what I need to do to get my cabinet simulator to work similar to the redbox. Any help would be great.
- Barcode
This is a little confusing. Generally, the purpose of a cab simulator is to attenuate and filter frequencies in such a way that a direct guitar signal sounds as though it is a miced cabinet. If you have a cabinet, why do you need a cabinet simulator?jimosity wrote:OK - So I have a cabinet simulator circuit.
- jimosity
For direct recording with a head that needs a load on it. The Cabinet Simulator is not a load device and I want to be able to record the tone of the head itself. It doesn't have an effects loop so I can't put the Cab Sim in the loop, bypassing the power section, so between the head / cab seems to be the only place it can go.Barcode wrote:This is a little confusing. Generally, the purpose of a cab simulator is to attenuate and filter frequencies in such a way that a direct guitar signal sounds as though it is a miced cabinet. If you have a cabinet, why do you need a cabinet simulator?jimosity wrote:OK - So I have a cabinet simulator circuit.
- Fender3D
1) your head MUST be connected to a proper load, expecially if it's a tube amp, (it must be a tube amp, otherwise what tone are you talking about?)
Wrong impedance settings, in tube amps, are somewhat expensive...
2) you must check what's the max input level you can apply to the sim, then you may add a damper (2 or 3 resistors) to reduce your head's level to a safer amount.
- Fender3D
I have 8 of these http://it.mouser.com/ProductDetail/Arco ... Wt7Wy1k%3d on a heatsink.
If you're just adjusting an amp they're perfect
BTW I guess the sim above has a higher input impedance than 8 Ohms....
- grrrunge
THe behringer GI100 does exactly that, it's dirt cheap (29EUR at thomann) and could save you a lot of trouble
http://www.behringer.com/EN/Products/GI100.aspx
You could connect that between your amp and cab, as you would normally connect a redbox, disable it's internal cab sim, and then patch in your own cab sim circuit in between the GI100 and the console.
I use the GI100 all the time for recording, and it's an awesome piece of equipment IMO. Especially when you consider the price too...
I got drunk with an old friend the other day, and recorded him for shits and giggles with the GI100 straight to the console and a condensator mic out front. Listen here, and see if you like the sound of it: http://arbitrage.graudal.dk/
- FiveseveN
By the way, the GI100 is a redbox clone, in case the fact that it's a red box didn't tip you off
- jimosity
I need a solution where I am using my cabinet simulation and circuitry that I can put into my own enclosures, reboxing a Behringer isnt quite suitable for my needs.
I dont mind using that schematic, but Ive not had any luck at finding a good transformer for a decent price. i do intend to sell these, so $80 jensens arent really practical.
