Noiseless Biasing, 470k or 4.7M series resistor?
Locked
matt239
Has thanked: 59 times
Been thanked: 5 times
Post by matt239 »
I've seen R.G.'s noiseless biasing described as using a 470k or a 4.7M series resistor after the 10k/10k voltage divider. Which is it?
How does the value of this resistor affect impedance? How is this calculated??
Thanks, all. 8)
Ihunda
Has thanked: 48 times
Been thanked: 7 times
Post by Ihunda »
Bumping the thread, I'd really like to understand why this creates less noice!
merlinb
Been thanked: 160 times
Post by merlinb »
http://www.geofex.com/Article_Folders/m ... dmuamp.htm
With the stock arrangement half the power supply noise is fed to the base of the upper transistor, and is passed to the audio output.
With the 'noiseless' arrangement the PSU noise is decoupled to ground. R.G also mentions Johnson noise and excess noise, but they are negligible in this situation, with either arrangement.
Locked
