TC Electronic - MojoMojo
KindlyKiller
Post by KindlyKiller »
Stupid name, I know - but listen to it.
IsakaJr
Post by IsakaJr »
SOunds like.... Looks like..... A TIMMY!!!! :horsey:
Lucifer
my favorite amplifier: Vyse BBQ Blue
Has thanked: 89 times
Been thanked: 72 times
Post by Lucifer »
The MojoMojo's a tasty sounding pedal - and one of the few that I've wanted to get my hands on.
Anyone got one 'undressed' yet ? :twisted:
bancika
Has thanked: 16 times
Been thanked: 88 times
Post by bancika »
I'd like to see it too. Considering buying one since I'm on the market for mild-ish transparent, open sounding pedal. Kinda opposite of TS :)
ct88
Been thanked: 9 times
Post by ct88 »
i have it, tell me if some1 is still interested, i'm gonna try to unmount the pcb from the schassis
BTW, right now is only 49euros here in Europe, you can finally buy it easily
ct
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Sure, I guess it's a Timmy clone, but who knows?
clintrubber
Been thanked: 5 times
Post by clintrubber »
roseblood11 wrote:Sure, I guess it's a Timmy clone, but who knows?
No, different (more elaborate) circuit.
I like it (at least for the EU49 :lol: ), but would have liked to have some more clean boost available.
okgb
Has thanked: 222 times
Been thanked: 38 times
Post by okgb »
Curious too , I saw one for a good price but no reference what it may have been based on.
clintrubber
okgb wrote:but no reference what it may have been based on.
I thought it's some EQ-shaping, a clipping stage & a Baxandall-type EQ-section.
I thought the schematic was out somewhere, but that might have been the brother-pedal (Dark Matter)
Bye
FeVeR2112
Has thanked: 47 times
Been thanked: 60 times
Post by FeVeR2112 »
Anyone still interested in this pedal? I will have one in the shop soon...
caspercody
Has thanked: 34 times
Been thanked: 48 times
Post by caspercody »
Yes. very interested.
Chugs
Has thanked: 63 times
Been thanked: 47 times
Post by Chugs »
Possibly similar topology to the Dark Matter but with different values?
clintrubber
Chugs wrote:Possibly similar topology to the Dark Matter but with different values?
Could very well be. Thought I'd seen the DM-sch long ago, but don't recall the details. Thought it was in low-res as well.
Always nice to know how it's doing it's thing (/mojo)
Unrelated, the MojoMojo has for now left the board. I was better served by a clean boost, which the MojoMojo doesn't really do (but in all fairness, I don't blame it for that)
Chugs
Post by Chugs »
Dark Matter Schematic is here. Possibly uses the same board as the Mojo Mojo with different values and/or a few different parts. There are unused parts places on the Dark Matter boards.
https://www.freestompboxes.org/viewtopic ... er#p260813
clintrubber
Thanks, that'll indeed be the spot were I saw it.
Bye
FeVeR2112
Post by FeVeR2112 »
Just received the unit from a local. I will setup for hi-res gut shots - it is all chicklette parts so caps will be a problem to figure out but I will do an in-situ measure.
First pictures show an interesting case design with a contact switch for when it it opened.
More to come.
Ice-9
Has thanked: 134 times
Been thanked: 359 times
Post by Ice-9 »
Looks pretty similar to the internals of the TC Dark Matter pedal, it has the same opto bypass setup as well. You may fid the trace easier if you check out the schematic for the dark matter pedal.
The contact switch you refer to when opening the case is just a grounding tag.
FeVeR2112
Post by FeVeR2112 »
I noted several component areas unpopulated. Likely a common circuit board that can do multiple pedals. I will put it under the microscope this weekend.
caspercody
Just wanted to see if any updates on this one?
FeVeR2112
Post by FeVeR2112 »
I have been swamped with work and a crappy flu.... it will be a week or two yet.... sorry :(
