ts808 with a blend control
bencoles
Post by bencoles »
hi everyone
what would be the best way to have a ts808 build where i can blend the original, ie clean guitar signal in as well?
juanro
Has thanked: 51 times
Been thanked: 117 times
Post by juanro »
I don't know if you're looking for an "exact" ts808, if not, this is something along those lines:
http://runoffgroove.com/ubescreamer.html
Note that you can replace the two 100K resistors before the last stage U1E with a 250K Lin pot and have a blend.
Hope this helps, regards.
Juanro
bencoles
Post by bencoles »
ive found this one out. http://diy-layout.com/29
Where would the best place to 'stitch' it into the circuit, if i want to have the blend on all the time.
could anyone help???
blackbunny
my favorite amplifier: Fender Blackface
Completed builds: Lots of mods to lots of pedals
Has thanked: 271 times
Been thanked: 105 times
Post by blackbunny »
Check out the Voodoo Lab Sparkle Drive circuit. It's basically a Tube Screamer with a control to blend the clean signal with the OD signal.
viewtopic.php?f=11&t=1802&p=21776&hilit ... ive#p21776
asatbluesboy
Has thanked: 38 times
Post by asatbluesboy »
Why not just building a Tube Screamer with a B Blender?
...collectors together and emitter to base? You're such a darling...
ton.
