Tone Monk - Seed of Life
method
Been thanked: 38 times
Post by method »
I took this from screenshot of youtube video.
Not sure what the op amp says. Either "TLC XXX" or "TL0 XXX".
Maybe some idea what is under the goop?
http://www.thegearpage.net/board/showth ... st11138917
DimebuGG
Been thanked: 198 times
Post by DimebuGG »
"Our Seed of Life Professional Overdrive was developed for guitarists to end their ultimate quest for tone. In the beginning of 2010 we released our Seed of Life VII and took the circuit a few steps further. There are several features in the circuit of the Seed of Life that allow you to actually control your tone. An Input control that controls your input the way a tube preamp does. With the texture options and controls of this pedal you have the power to shape your tone in ways you have never heard it before. The 3-way texture switch offers an array of saturations from transparent to colored tube driven qualities. The Form EQ control allows you to roll off high end frequencies at half the rate that it accentuates low-mid frequencies, in reaction to the texture you choose, to 'form' your over all tone. The drive control works as gain drive saturation. All controls interact with each other, so you can literally get thousands of sweet spots and finally have the ability to create your own sound.
The Lush/Fat option allows you to choose between the standard rich tone of the Seed of Life and a wider tonal option. Many players who use a combination of Humbucking, Single coil, and P90 pickups find this feature to be extremely useful and a breeze to compensate for the change in pickup output/tone on the fly without having to actually change the tonal settings on the pedal."
The W-20K Tone pot, the Drive pot wiring, and the Volume = ____________
Cannibal
Has thanked: 27 times
Been thanked: 15 times
Post by Cannibal »
DimebuGG wrote:The W-20K Tone pot, the Drive pot wiring,
also, a 3 way diode switching and a 2 way cap to ground switch (in the feedback of a non-inverting opamp). All those things make me think about it being a (drum roll).... TUBE SCREAMER :horsey:
Seiche wrote:there's a difference between being drugged (I don't think it was only booze) and retarded.
bubstance
Has thanked: 75 times
Been thanked: 116 times
Post by bubstance »
The IC is a TL072CP.
Source.
theblackman
Has thanked: 10 times
Post by theblackman »
wow that almost looks as poorly made as one of my pedals!
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
method wrote:Not sure what the op amp says.
It says "Heeeeeelp, the oil spill is coming at me!!"...
Sorry about that...
Anyway, I can guess LEDs as clippers above the IC. A HB-alike?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
MarkF786
Post by MarkF786 »
From another thread, Burglar pointed out that it looked like a GGG TS PCB. I just compared my pedal with the GGG TS PCB & component layout and everywhere I can see a component or wire on the PCB, it matches.
I remember seeing a gut shot of his Phoenix (Klone) which is also gooped and remember thinking it looked like the Madbean PCB. I'll try to track down a the gut shot to confirm.
jakeddy
Post by jakeddy »
I have one that has no goop. It's a dead match.
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
mods, maybe fuse the two threads as to make it easier to keep track?
