Speaker and Cab simulators
pz
Been thanked: 48 times
Post by pz »
phatt wrote: Can't comment on Victor K except to say the When i tried to use discreet fets in the building of my tone circuits and like stuff ,,, well it worked but noise was a problem. Unless something stunning can be shown it really is much simpler to use a chip.
I bet, not noisier than the LXH Fender i just found in the drawer, built many years ago using prehistoric 741's ;)
I haven't seen many build reports about these speaker sims, probably due to rather complex schematic and the lack of "vero".
So, as a reference and to add more data to this thread i have just recorded a short riff using my home build 4W tube amp and RLC dummy load straight into the LHX Fender cabsim.
Plus a real frequency response of the unit.
Personally i find the sound a little bit too dark.
Sound sample
Schematic
Frequency Response
Frequency Response
LHX Fender Spectrum2.png (9.18 KiB) Viewed 3373 times
KMG
Been thanked: 80 times
Post by KMG »
A way to simulate sound using micro PA, load eqivalent & speaker/mic response simulator.
PA (250mW)
PA schematic:
http://milas.spb.ru/~kmg/files/projects ... croSch.pdf
Equivalent/Sim schematic:
http://milas.spb.ru/~kmg/files/projects ... im/sim.pdf
Frequency response Cab/eq+sim:
Comparative samples, cab_s - micro pa 250mW on 4x12 cab (mic E906 2 sm side from speaker center), cs_s1 - micro pa on complex load simulating speaker impedance + speaker simulator.
http://milas.spb.ru/~kmg/files/projects ... _cab_s.mp3
http://milas.spb.ru/~kmg/files/projects ... _cs_s1.mp3
pz
Post by pz »
Cool stuff KMG! :thumbsup
rcustoms
Has thanked: 363 times
Been thanked: 518 times
Post by rcustoms »
great job :applause:
have no problem if we could see the entire work,your approach is very interesting and we have more to learn about it
guitars,pedals and amps.
@zuleta.rafael(Instagram)
KMG
Post by KMG »
Full micro PA project
Image Image
Image Image
Speaker equivalent & sim just prototypes, not finished yet
rcustoms
Post by rcustoms »
thanks,can you show connector details j1,j2,j3
KMG
Post by KMG »
J1 input
1- signal input.
2- signal gnd.
3- 12V (output to possible fet preamp).
J2 feedback (possible Presence/Depth controls)
1- feedback output from OT.
2- feedback input.
3- gnd.
J3 output/PSU
1- PA output (load).
2- gnd (load/PSU).
3- 12V input from PSU.
uncleboko
Has thanked: 57 times
Been thanked: 38 times
Post by uncleboko »
pz wrote:
rcustoms wrote:http://www.hexeguitar.com/diy-cabsims_e
thanks to mr darthoverdrive for info
I wrote this article, i believe back in 2003. A few years later, with the help of Teemu and Markus it was translated into English.
I wanted to create a kind of summary of different speaker simulators on the market or known diy projects.
For years my preferred cabsim type was one setting on Marshall SE100. About 2 years ago i posted a project of a stripped down version of the SE100 - SE33. You can find all details (schem, pcb) here:
http://www.hexeguitar.com/diy-se33_e
Sound sample
At some point i decided to design my own speaker sim, but instead of trying to simulate a particular type of box i took another path: adjustable presence and low thump control a parametric mid notch filter. The prototype was breadboarded and tested, but after that i pretty much lost interest in analog "EQ" type speaker simulators. Turned out, that the digital techniques provide much more realistic results, at least for me. The simple LP+HP + sometimes a mid notch filter approach does the job well for clean and light crunchy sounds, but in my opinion it fails in case of heavier sounds. A real speaker frequency response has many peaks and notches, which among other factors are responsible for the typical "granular" hi gain sound. Something that all those simple cabsims lack of (well, maybe except the LHX design).
For a comparison, check out the frequency plots of the Korg PX4 speaker simulator section at the end of the article.
I could find the notes and schems and post the tweakable cabsim if anyone is interested. I believe, i have a few soundsamples somewhere, too.
It would be nice to have the article updated with corresponding sound samples. Maybe i'll try to breadboard the circuits and record a few sounds.
Frank Nitsch created a nice speaker sim comparison with a lots of sound samples. Worth checking:
http://www.franknitsch.com/speaker-sims/
Piotr
There seems to be an assumption that the required sound is gross distortion - wrong.
pz
Post by pz »
uncleboko wrote: There seems to be an assumption that the required sound is gross distortion - wrong.
Then you haven't probably noticed i used "for me" or "in my opinion" several times. I'm just sharing my point of view, not trying to preach.
_In case_ of hi gain sounds a simple analog speaker simulators do not work for me. In other cases they did, many times.
rcustoms
Post by rcustoms »
the Speaker emulation should be good on both clean and drived or distorted,correct me but the cab emulation has nothing to do with the preamp or pedal that we use,unless we add some control to enhance the distortion and make it more real.
okgb
Has thanked: 222 times
Post by okgb »
I think using a transformer is a key factor for the gtr signal , even cheaper ones on splitters
seem to sound better , my best efforts for non mic recordings have been into a millennia STT 1
mic preamp with transformer selected , and don't be afraid to apply as much EQ & compression as it takes .
Although some people may think they are losing dynamic range , the sustain from compression makes it
easier to play in headphones . Nice work lads , i wish i wasn't so overloaded in building projects !
rcustoms
Post by rcustoms »
unverified pcb speaker simulator based on mr Piotr z. work.stay tune for pcb based on mr phil
rcustoms
Post by rcustoms »
PCB REV 1.1 UNVERIFIED
KMG
Post by KMG »
Micro PA, load equivalent & speakersim assembled in box.
kleuck
Completed builds: I build and sell my own :)
Has thanked: 42 times
Been thanked: 27 times
Post by kleuck »
I made a cheap and passive LSPkr simulator, not perfect i suppose (but really good enough by ear) inspired by this one : http://scopeboy.com/ssim.html
Here's mine, was meant to emulate a Jensen P10R at the time : Image
Randall Aïken said :
meffcio
Been thanked: 14 times
Post by meffcio »
rcustoms
Post by rcustoms »
good link :applause:
rcustoms
Post by rcustoms »
dont forget sansamp gt2 speaker emulator stage
phatt
Been thanked: 338 times
Post by phatt »
Hi PZ, Thanks for sharing.
Yeah this stuff can be done in so many different ways it's easy for the novice to miss the detail.
You obviously have a Valve Amp to work with but other folks may only have a SS setup so you have to approach things in a different manner.
Re Valve outputs;
I did research a lot of the RLC stuff but (as I mentioned earlier in this thread)
I found it far simpler to implement a simple load R followed by a voltage division running into a graphic EQ > onto poweramp or direct to recording.
I agree that IF the tube amp delivers close to the required tone shape it takes little effort to get great things to happen.
Some tube amps will obviously need more tweaking and my Valve setup like yours does not need much to capture the tone.
In testing both my Reamplified Valve poweramp setup and my Hybrid SS setup there is only a slight improvement with the Valve powerstage soaked.
Examples;
1/ FPV (PhAbbTone) > DDC > Graphic > Old Laney Keyboard Amp.
2/ FPV (PhAbbTone) > Valve Amp > Load box > Graphic > Laney Amp.
(The Valve pwr stage does sing a little better.)
Both these setups reap very similar results and I negate a whole mine field of Mathematical RLC Gymnastics.
I went thru months testing all kinds of RLC stuff for Valve outputs and IMHO they are a pain to work with. Big clunky inductors, coneless speaker, iso cabs, the list goes on.
Sorry but Iza been around too long to waste time on stuff that just complicates a simple issue. A lot are overrated (for what they deliver) when an old HiFi Graphic can open a whole list of different results. I just added a switch and 2x 6.5mm sockets on the GEQ and threw the silly stuff in the bin.
Note For Valve Amps*
The Load R was my biggest hurdle until I found a small bit of text written by the maker (I assume) of the UA (Ultimate Attenuator).
(and without side tracking this too much)
The Load R is a big factor.
An 8 Ohm System needs around 3 to 4 times the R to match the Z so I use 24 Ohms Load R. this overcomes a lot of the RLC voodoo maths.
Using 8 R load just turns your Valve Amp into a fizzy SS sounding dirt box and kills any chance of sustain.
That's why simple Attenuators don't work you need to Re EQ and Reamplify it other wise they sound rather bland.
To give you an idea about the liquid sustain I wanted, Google *Guytron GT100*,,, that is the sound I wanted to achieve. (it's a Reamp All valve setup, 2 Amps in one box)
I feel that with some SS circuit tricks I maybe able to replicate the Guytron but the sustain is very hard to nail down when competing with all Valve.
I'm still not quite there but I'm getting closer. Winky.
Meantime back on topic,
The Valve front end (on Example 1 above) does a pretty good job and I use it more than the other. (One less box to cart around to gigs, Even small Valve Heads are heavy)
If I was to start all this all over again I would certainly take *KMG's* great work and test it out as it does look promising. But I have the liquid tone of Guytron implanted in my head and it won't go away easy. [smilie=vibes.gif]
I did actually try some of your circuits but it was so long ago I forget which ones,,, might of been the one with lots of opamps which I felt was getting way to complex for what I needed but hey It obviously works. :thumbsup
Phil.
phatt
Post by phatt »
rcustoms wrote:dont forget sansamp gt2 speaker emulator stage
I just simed that and the *top end roll off is very close* to the traces I posted before.
Problem is,,,,,, it has NO Roll off in the low end,, :scratch: maybe it's not the whole circuit.
Phil.
