First, I'm building a Meathead, one of the caps says is 47pf, but the lower cap I found is 100pf. Would it be much of a difference? I see that the One Knob Fuzz uses 220pf in that position, but also some other values change. Should I try to find a 47pf?
Second, is there any difference when using capacitors of a higher voltage? I have a couple of 200V and 400V capacitors I could use, and I see some builds with big capacitors like these, including the ones from DAM. But what's the difference with using regular low V caps?
That's it, thanks!
