Page 7 of 7
Re: Eagle Tips, Tricks, Help and other Useful Information
Posted: 10 Mar 2012, 15:41
by Bside2234
Well it looks like you have "vb" coming off the supply filtering and "-vb" on the main circuit. If you mean for them to be connected, change the -vb to vb. If you don't mean for them to be connected there is nothing connected to vb or -vb.
Posted: 10 Mar 2012, 16:03
by Chugs
Ah, I see. I have used differently labelled pads. Thanks.
Posted: 10 Mar 2012, 20:12
by Chugs
What is the difference between using the LINE tool and the NET tool to connect components? I have watched a couple of Eagle video tutorials where the Line tool is used to connect components but I have also that using the Net tool is recommended to connect components.
Posted: 10 Mar 2012, 23:44
by marshmellow
From the
official tutorial: "Do not use the WIRE command to draw net or bus lines in the schematic. Use NET or BUS instead!"
Definitely recommended to read instead of watching videos by experts
Posted: 11 Mar 2012, 11:16
by Chugs
I agree. I should have read the official documentation first.
Posted: 11 Mar 2012, 17:08
by Bside2234
Crap! So I should have been using the Net tool and not the wire tool all these years!!!!
Posted: 11 Mar 2012, 18:38
by ~arph
Yes..
This will help you ensure everything in your schematic is connected properly in your PCB too.
Posted: 21 May 2015, 15:59
by darthoverdrive
If this is in the wrong area please let me know.
I have a design I want to share in the Ready To Build Projects if I can ever get the PCB portion done.
I’m using an opamp to create my ½ voltage reference. When I check for errors on my schematic I get the following errors;
OUTPUT and SUPPLY pins mixed on net VR. Also the POWER going to my opamps show a warning. Is it ok to approve these or is there something that I’m missing in the layout?
Posted: 21 May 2015, 20:49
by grrrunge
darthoverdrive wrote:If this is in the wrong area please let me know.
As long as "the error makes sense", it's okay to approve
I've had quite a few PCB's fabbed, with the two errors you've just mentioned. Those are more like "Are you sure this is how you'd like stuff done?" messages
The reason the power pins throw an error is that they will automatically connect to certain nets (V+ and V- i think). The one with output pins to supply nets - no idea...
