Measuring gain and leakage in germanium transistors
- noelgrassy
- my favorite amplifier: MOTS Magnatone & Trainwreck
- Completed builds: Tonebender Mk II w/ 3 OC75's, Burns BuzzAround w/NKT 275,Rangemaster w/ OC44, Fuzz Face w/ SKS363's, CJOD, Harmonic Percolator w/2N404A & 2N3635(vintage correct box,sliding pots, 1%glass resistors),Stack-O-Dimes & Whipple Wahs,
- Has thanked: 11 times
- Been thanked: 3 times
I recieved this from a helpful gentleman named Димитър Димитров ---- Measuring of germanium transistors with digital multi-meter may be very inaccurate due to several reasons. Our engineer Mr. Plamen Vasev (dpebay@abv.bg) has invented a new method to check quality of germanium transistors via two measurements of the base current. With this we calculate the gain and also can conclude for what the measured transistor can be best used. 1. The leakage current Icbo is measured first. 2. Then the base current Ib is measured at fixed collector current Ic (eg. at 0.5 mA, fixed by a resistor connected to the emitter). 3. Finally the gain hfe = Ic/(Ib+Ibco) is calculated. Example: If Ibco=4µA, Ic=1000µA, Ib=12µA, then hfe=62.5 If this example transistor was measured with a digital multi-meter it would show a figure about 100!! or about 60% error!!!???
Best Regards,Dr. Dimiter Dimitrov Manager BgEbus Is this method different than the one you longtime EE typed have been using?
- noelgrassy
Darn thing must have thought my fluent use of Cyrillic was some kinda "cussin'". Well, it's merely a gentleman's appellation. Pussy fucking software shit. Thankyou for reading anyway, NG
Mr. Vasev is a little late.noelgrassy wrote: Measuring of germanium transistors with digital multi-meter may be very inaccurate due to several reasons. Our engineer Mr. Plamen Vasev (dpebay@abv.bg) has invented a new method to check quality of germanium transistors via two measurements of the base current.
See "The Technology of the Fuzz Face" from 1998 at GEO http://geofex.com/Article_Folders/fuzzface/fffram.htm. It wasn't new when I wrote it up, as the early testers back in the 60's did this as well.
Yeah, it could - except the leakage number is useless. Silicon has well over a thousand times less leakage than germanium (or should!) so any silicon that shows any "leakage gain" at all should be tossed in the rubbish bin.Stuggi wrote:Here's the circuit that's used for testing 'em AC128's
Could this be adapted to NPN silicon transistors as well?
- noelgrassy
Stuggi wrote:Will the circuit work as it is with a NPN or do I have to reverse the power source?
