The Sweeper
ricker
Post by ricker »
I have one of these. It works, though it is part now. The footswitch is missing.
Anyone ever seen or heard one? Kind of a funky little box that I'd like to get back together once I order a switch.
Here is an ebay auction of one for reference. This is not my auction!;
https://www.ebay.com/itm/280605038618?s ... 1423.l2649
ricker
rocklander
Has thanked: 1401 times
Been thanked: 227 times
Post by rocklander »
do you have the facility to take gutshots? :block:
ricker
Post by ricker »
Sure do. I'll try and get some put up tonite.
ricker
Post by ricker »
Here are the shots;
rocklander
can't find much info on the TA75747P
on google, I see an AD7574 8 bit DAC.. (whatever that means) :lol:
lolbou
Has thanked: 295 times
Been thanked: 200 times
Post by lolbou »
Looks Coron-esque and phase 90-esque too...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
pedalgrinder
my favorite amplifier: Ampeg SVT
Completed builds: pedals with pots switches and everything
Has thanked: 198 times
Been thanked: 164 times
Post by pedalgrinder »
an 8 bit dac is a digital to analog converter 8 bit but i very much doubt thats what its using i also searched the net high low up and down and found nothing on that IC bit of a mystery hardly worth tracing if we can't work out what the ic is.
mictester
Has thanked: 27 times
Been thanked: 784 times
Post by mictester »
rocklander wrote:can't find much info on the TA75747P
It's a cheap dual op-amp. Back in the 1980s it was considered "low noise".
Looking at the effect, it looks very much like an unusual layout for a basic four-stage phaser.
tube-exorcist
Has thanked: 173 times
Been thanked: 65 times
Post by tube-exorcist »
Since when a (dual) 741 was considered "low noise" back in the 1980s ?
TA75747P = µA747 = dual 741
ricker
Post by ricker »
I found this. Hope it helps;
ricker
Post by ricker »
Resized. Hope this one fits. Sorry.
pedalgrinder
The problem here is not working where the tracks go and the values it's what are the TA75747p Toshiba chip is. Once thats worked out the pedal can be traced and schematic can be created.
tube-exorcist
pedalgrinder wrote:The problem here is not working where the tracks go and the values it's what are the TA75747p Toshiba chip is. Once thats worked out the pedal can be traced and schematic can be created.
Careful reading can be helpful occasionally:
tube-exorcist wrote:TA75747P = µA747 = dual 741
µA747 = LM747
www.national.com/ds/LM/LM747.pdf
mictester
Post by mictester »
According to the specification I've seen, it was supposed to be akin to a dual 741S (which was the "low noise" version). I always suspected that the "S" versions were just "selected" - the ones that hissed a bit less in their test jigs! I remember these ICs being used in Marantz tuners as the audio output buffers!
ricker
Post by ricker »
Thanks for all the comments! I found this list, which I'm sure you are aware of;
http://www.ic2ic.com/search.jsp?sSearchWord=TA75747P#
pedalgrinder
If thats just a dual 741 why is it so damn hard to find out what it is. I read exactly the letters i could see on the chip. What else can you go by. Is there somewhere online i don't know about. Or is that from experience you know that chip is that. I don't say that sarcastically i want to know how you did it so i can in the future. Thanks
