image host
upload images
fretzburner wrote:Thanks DrNomis for the helpful tips.I am just doing it for my personal use and don't have those great equipments.Maybe I could do it with just a multimeter.I will try the cathode bias method and measure only one tube or maybe try to measure the other tube just for reference if they have almost same reading.Is it necessary to install a second bias pot ?If i will,is it that simple just to separate the two 220k resistor and duplicate the resistor/pot,cap from the rectifier and connect the second in parallel with the original bias circuit? please check my schematic.
image hosting png
A bit is a understatement.DrNomis wrote:
If the plates of the power tubes are glowing a bit red then it means that the tubes are biased a bit too hot, or maybe the coupling caps on the grids are a bit leaky, personally I like using the signal-generator, dummy-load, and scope method of setting the power tube biasing.....
Depends on the amp (which i believe has never been established). Balance pot setups are rarer, Fender started phasing them in in '65 (on the Bassman). It was a horrid idea that resulted in more hum than ever and not being able to adjust the bias in one half at all. One of the most popular mods to to scrap the balance pot and install a bias pot setup.Zipslack wrote:I may be completely wrong here, forgive/correct me if I am. The way I understand it is that the bias pot is mis-named and should be called a "balance" pot. It does not necessarily change the bias of both tubes, but just balances the bias to help eliminate cross-over distortion. This makes it easier to use tubes that are not "matched". Adjust it so both tubes pull the same current --> 1. Does it sound good? 2. Are the tubes red-plating? If it sounds good and isn't red-plating, play it.
