D*A*M - 1966 Italian Tone Bender
beedotman
Has thanked: 402 times
Been thanked: 393 times
Post by beedotman »
Yo!
Layout for latest revision of D*A*M 1966 (sadly discontinued)- vox tone bender replica.
Instead of switching output capacitors as in old version - in new, super bee switch changes resistance of output pot from 470K (super bee mode) to ~42K (1966 mode) - really fun mod! Another change due to old layout - now bias trimpot is on Q1 collector.
Instead mounting two output parallel capacitors (C3 - Iskra's 4700pF and C6 - Xicon 2200pF) - You can remove C6 and change C3 to higher value to (6800pf will be the closest value, but 8200pf/10nf/15nf sounds cool, too).
Enjoy! :thumbsup
beedotman
Post by beedotman »
and here's pic of hidden cap under board
I know there are standoffs and all, but man, I would've definitely put some insulation on the leads of that cap on the bottom of the board.
beedotman
Post by beedotman »
RnFR wrote:I know there are standoffs and all, but man, I would've definitely put some insulation on the leads of that cap on the bottom of the board.
true! :thumbsup
beedotman
Post by beedotman »
And some more guts with different trannies combo - Texas Instruments OC82D + Mullard OC76 and Mullars OC71 + OC83.
beedotman
Post by beedotman »
Redrawn layout with full wiring under turretboard.org label :horsey:
1966.pdf
(20.23 KiB) Downloaded 237 times
:mrgreen: My new project maker! Thank you in words :thumbsup
beedotman
Post by beedotman »
sinner wrote::mrgreen: My new project maker! Thank you in words :thumbsup
[smilie=drink.gif]
Solidhex
Has thanked: 10 times
Post by Solidhex »
Those are half inch standoffs. If you're worried about those legs shorting to the enclosure its not really a possibility.
G5120fx
Has thanked: 37 times
Been thanked: 29 times
Post by G5120fx »
I´ve build it yesterday, and its a nice sounding fuzz! I used Ac122´s (as always, I bought 100 pieces once).
It´s supposed to have not much sustain right? Italian Tone Bender --> Spaghetti Western --> little sustain right?
beedotman
Post by beedotman »
G5120fx wrote:I´ve build it yesterday, and its a nice sounding fuzz! I used Ac122´s (as always, I bought 100 pieces once).
How short is sustain? It shouldn;t have sustain similar to let say Buzzaround or MKII, but it shouldn't be very short though...
G5120fx
Post by G5120fx »
ok, there must be something wring then. The sustain is shorter compared to the MKII.
I´ll check it again... Which hfe´s did you use?
beedotman
Post by beedotman »
G5120fx wrote:ok, there must be something wring then. The sustain is shorter compared to the MKII.
It' dependts... usually Q1 around 60-75 and Q2 70-110.
beedotman
Post by beedotman »
small veroboard version with bias on Q2C and socketed trannies
should fit 1590B or 125B easily
66_fuzz.pdf
(71.94 KiB) Downloaded 161 times
agoldoor
Has thanked: 39 times
Been thanked: 21 times
Post by agoldoor »
beedotman wrote:Redrawn layout with full wiring under turretboard.org label :horsey:
Pics of a build I did with this layout:
photo (17).JPG (57.54 KiB) Viewed 4402 times
controller700
Post by controller700 »
That is a great looking 1966!
From where did you get the rotary switch? I can´t find a rotary with only two positions...
What hfe values did you use for the trannies, and how close does it get to the "real thing"? 8)
beedotman
Post by beedotman »
controller700 wrote:That is a great looking 1966!
It dont need to be two position rotary switch, it could be with three or four positions - You can always limit amount of positions on rotary switches. Good idea is to use 3 pos. switch, two for mode changes and third for switch off battery.
controller700
Great idea! :thumbsup
I never used these before..
beedotman
Post by beedotman »
Here's for example 12 position 1 pole switch - top view.
In red are marked slots that You can use to limit number of positions from 2 up to 11, it's really quite easy to do :thumbsup
G5120fx
Post by G5120fx »
I built the new vero yesterday, and i really like it. It´s a little too dark sounding with my Gretsch?! Should I experiment with the 6,8nf to get a bit more treble?
THX
