How to switch between 3 caps with a toggle switch?
Visualdistortion
my favorite amplifier: Laney
Completed builds: Many...
Been thanked: 23 times
Post by Visualdistortion »
Hi, I would like make a pedal with 3 differents caps values, what switch can I use instead the rotary switch? (so big)
I wanna make it
I wanna make it wit chu
(again and again and again)
French... sorry ;)
juanro
Has thanked: 51 times
Been thanked: 117 times
Post by juanro »
Use a center off spdt (on - off - on). Connect the lower value of the three caps (C1), with the switch in parallel and a cap on each side with values such that C1 + C2 = the 2nd value you want and C1 + C3 the 3rd.
Something like this:
Sin título.png (7.79 KiB) Viewed 568 times
Hope that helps, regards.
Juanro
