Help with wiring please
romily
Post by romily »
So I'm a complete beginner and I'm building this smokey amp circuit, would really appreciate some help
i was wondering if someone could please tell me how to wire in a couple of things to this
a 3 pin volume pot
a jack output so it can be wired into a big speaker (im still putting in a small speaker as well)
a power output (im using the battery as well but want to be able to plug it in too)
thanks so much!
romily
vero layout
vero layout
greenskull
Has thanked: 33 times
Been thanked: 8 times
Post by greenskull »
I just replied to this and my reply just disappeared.... topic must have been moved? Well here is again:
You will need a switched power socket (3 solder terminals) and a 1/4" stereo input socket to turn battery or external power on/off. You can also use a mono socket and add a separate power toggle switch instead. For basics on wiring stuff, I would suggest perusing the generalguitargadgets.com tech and project pages.
Also check out the Ruby amp project at runoffgroove.com for ideas of what you can do with this circuit.
romily
Post by romily »
cheers greenskull. loads of useful info on that ggg site. thanks for the tip
