ExpressPCB Tips, Tricks, Help and other Useful Information
vanessa
Post by vanessa »
Post any tips, tricks, useful information, and if you need any help with ExpressPCB here is where to post it.
John Lyons
Been thanked: 29 times
Post by John Lyons »
I like ExpressPCB because it's so simple.
Now if only was possible save files from the actual application as sized layouts!
I use the "print screen" key and the resize in photoshop.
I scanned a piece of perf at 100% to get a .1 grid as a template for spacing. Save at 300dpi
Here's how I resize ExpressPCB (and other) layouts in Photoshop
In ExpressPCB: (with your layout finished)
Make the image as large as you can on the screen while not cutting any off
Hit the Print screen key on your keyboard.
In Photoshop: select File>New and change to 300 DPI
Paste the file into the new window. (Control V)
Open the perf/grid template and copy/paste (Control C, Control V) into the layout trace window.
Select the template layer, right click, blending options. Slide the bar over until you get roughly 50% opacity and you can see the template behind the traces.
Click on the trace layer, and select it with the cursor.
Edit > transform > scale. Then drag the trace layer around until the ICs or transistor pads are within the right size dictated by the template spacing.
IC, transistor, resistor and Cap pads will fall into the grid spacings.
Take a look at the Express PCB grid and how it lines up with the parts to make sure you get the vertical and horizontal spacing correct.
This is hard to explain, hopefully it's understandable...
John
Sock Puppet
Post by Sock Puppet »
Why not turn on a 0.1" grid view and work to that instead of the matrix board scan?
Holding down the shift key when reascaling will lock the aspect ratio too.
S.
John Lyons
Well...because that would be too easy!
(Slinks away....)
I learned something today.
John
devastator
Been thanked: 22 times
Post by devastator »
someone has the file to have a switch 3 positions for expressSCH ? like this one
I didn't find it on internet.
THX
Conguito
Post by Conguito »
John Lyons wrote:I like ExpressPCB because it's so simple.
If you use a virtual pdf printer you have a pdf file with the pcb layout ready for print.
devastator wrote:Hi,
THX
It's easy to design any custom component yourself in ExpressSCH, so you can number the pins like you need it, I've made very much components myself in ExpressSCH and ExpressPCB, so if you want to know how to do it I can show you how to do it.
Salu2.
John Lyons
VERY NICE! I printed a layout in Cutepdf and sure enough it saves and prints in 100% scale.
Thanks for that nugget of information!
john
