JHS - Morning Glory [traced]
- Jack Deville
- culturejam
Are those bad?Jack Deville wrote:MMKs??
I've used them in some builds and not noticed any issues. But then again, I can't hear mojo worth a damn!
- irmcdermott
I think it's a reference to the caps.coldcraft wrote:whats a MMK?
http://www.kemet.com/kemet/web/homepage ... 94_MMK.pdf
- Jack Deville
I think they are an acceptable solution for supply decoupling, but I do not recommend them for use as coupling capacitors where signal is present.culturejam wrote:Are those bad?Jack Deville wrote:MMKs??
- culturejam
Damn, that's a pretty negative thing to say about a film cap.Jack Deville wrote:I think they are an acceptable solution for supply decoupling, but I do not recommend them for use as coupling capacitors where signal is present.
- Jack Deville
Take the Pepsi® challenge!
- phibes
Those meddling cheap film capacitors! Always ruining the toanz!
Ken
Ken
- atreidesheir
Does anyone else share Mr. Deville's negative opinion of the MMK film caps?culturejam wrote:Damn, that's a pretty negative thing to say about a film cap.Jack Deville wrote:I think they are an acceptable solution for supply decoupling, but I do not recommend them for use as coupling capacitors where signal is present.
I use greenies for some less common values so I probably would never notice the difference.
- phibes
They've sounded fine to me whenever I've used them.
Ken
Ken
- atreidesheir
just wondering. I have a lot of them ready to use.
- candletears7
Word on the street is, yes. I forget which street though.
Yep. According to JHS's site it's a modified Bluesbreaker:candletears7 wrote:Word on the street is, yes. I forget which street though.
"The Morning Glory is a very transparent tone-shaping tool that is the result of several years of building, gigging, tweaking and improving on the original Marshal Bluesbreaker design."
Is there a technical description on why the MMK type cap are not so good? I'm only a noob but I've used them in a few builds with no issues. My main point being I got about 100pcs for cheap and If their prone to failure or generally problematic I'd like to know. No financial loss for me but I'd rather not have to fix an otherwise good build if I can help it. I use them for signal caps in 9 volt transistor based circuits. Thanks for any info.
- jonasx26
Nope.onebuzz wrote:Is there a technical description on why the MMK type cap are not so good?
@jonasjberg http://futileresistancefx.blogspot.com
- irmcdermott
I wish I had one to fully trace, but someone I know who has a double barrel (but lives states away from me) was kind enough to let me know that the opamp is a LM833N.
