3- or more connector ribbon cable in Europe
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
Hey guys,
after seeing a couple of builds with ribbon cable for the pots, and sometimes the switch as well, i was thinking they look pretty neat. Any of you know a good (read: cheap) supplier that has them in a decent thickness (like regular stompbox wire) in lower quantities?
btw: that's how they look, can be multicolored, though i prefer unicolor. I would like at least 3-connector-ones or multiples of that (6,9,12 ...). If you only find in between numbers, please do post anyway.
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
www.bitsbox.co.uk does a 10-strand rainbow ribbon cable, it's a flat £1.50 delivery for any order, but is a little thinner than is absolutely ideal for wiring pots.
Has thanked: 218 times
Been thanked: 857 times
http://dickbest.nl/index.php?_a=viewCat&catId=153
Let me know if you need translation help
marshmellow
Has thanked: 19 times
Been thanked: 126 times
Post by marshmellow »
Standard electronics stuff like that can be found cheap at Reichelt in all kinds of variations. It's the go-to supplier in Germany for most DIY folks for a good reason. For example this one. I wouldn't worry about the thickness too much, these cables are inherently stable due to the parallel fixation.
