First post here , I have been trolling awhile and thought I would contribute. Here is the D*A*M Sonic Titan Schematic from a pedal that I have.. however it does differ from the gut shot In the peach fuzz Post. Mine does not have the resistor to Gate nor the Blue tant. in Parrallel with it . it is layed out close to the same and it is on vero board . Why There Different ??? ya got me .. i will post a layout when I get a chance.. also for the ones that dont know the single Black band resistors are ZERO ohm Jumpers . so they can be excluded and standard jumpers could be used... Thanks.... IC is LM386N-1.. have fun.. its a cool build. great pedal .. i would look at some changes to give a little more beef My actual D*A*M seems to be a little Mid rangey for my tastes.
Project name: D*A*M Sonic Titan
Group Name Value Part # Quantity
Capacitors C1, C2 4.7uf (2)
Capacitors C3, C5 .0047uf (2)
Capacitors C4, C6 10uf (2)
Capacitors C7 47u (1)
Diodes D1 1N4001 (1)
Integrated circuits IC1 LM386N-1 (1)
Resistors R1 4.7M (1)
Resistors R2 2.2K (1)
Pots R3*trimmer*, R4 24mm, R8 24mm 10K (3)
Resistors R5, R7 1K (2)
Resistors R6 9mm Bourns 100k (1)
Resistors R9, R10 0 Ohm *Jumpers* (2)
Transistors Q1 2N3819 FET N channel (1)
