Modern SLO 100 emulator
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
Am i the only one dying to try this one out!? :D
Anyone's got more info on it?
is there a schematic somewhere?
hbo
Has thanked: 28 times
Been thanked: 196 times
Post by hbo »
RnFR wrote:is there a schematic somewhere?
I based the layout on this schematic:
http://www.aronnelson.com/gallery/main. ... s.jpg.html
Seems like a reasonable schematic/circuit to my novice eyes, but I have no idea how close or far this is from the real thing.
oh yeah, I remember this thing. those MOS stages are freakin weird. I guess the idea is just to drive the hell out of the input of the device? it's supposed to be a new way to model a triode with 9v. i've tried to read the translated version of the the accompanying article, but it wasn't exactly what I'd call English. :wink: I'd still like to fool around with it sometime, though.
btw- Soulsonic designed a SLO emu called Freya a while ago that might be worth checking out.
phatt
Been thanked: 338 times
Post by phatt »
FWIW,,,,,,, @ 9VDC ,,,, you're all dreaming.
Built a few Fet circuits and even from 40 VDC they die in thar ass when called upon to perform.
Off course I reserve the right to be proved wrong :)
Have fun,,, Phil.
slammer88
Post by slammer88 »
what are these Red dots ?
Nicht Bernd
Has thanked: 98 times
Been thanked: 7 times
Post by Nicht Bernd »
Hi Slammer
The red dots are breaks in the copperlines. Do it with a 4mm drill by HAND. Only "drill out" the copper.
Have fun
slammer88
Post by slammer88 »
Nicht Bernd wrote:Hi Slammer
Have fun
Cool but, why would i need to? Isnt this project made over a PCB with full of holes like this? or is this a special one ?
http://www.google.com.tr/imgres?q=delik ... 9,r:17,s:0
deltafred
Has thanked: 808 times
Been thanked: 299 times
Post by deltafred »
Have fun
That is perf board that you have found, strip board or vero board is what you need the drill for as there are strips of copper running the length of the board, not individual pads round each hole.
See Ebay item 290651644504 for vero (strip) board
slammer88
Post by slammer88 »
Have fun
ah, now i see..thanks for the help ^^
zilla
Post by zilla »
Necrobump
I've been thinking about building this and have been trying to research it to see what it sounds like.
Has anyone built this? What does it sound like?
J0K3RX
Has thanked: 315 times
Been thanked: 555 times
Post by J0K3RX »
I made a layout for it but have not built it yet. I have heard sound demos of boards made with this Russian schematic and it sounds great! I have built most of them all working so I believe this will work. I added a "sweep" pot in place of R23... adds more tonal options
Board transfer
https://dl.dropboxusercontent.com/u/111 ... O-BURN.pdf
zilla
Post by zilla »
I am thinking of doing the veroboard version, but am a little confused on how I am going to add trimpots in place of those bias resistors.... Pin 1 to the 9v rail and pin 2 to the fet, but I am not sure how to make it fit and look "pretty".
How close do you think this sounds to a 5150 considering that the 5150 was based off of a slo 100?
J0K3RX
Post by J0K3RX »
well, you can add the trimmers on the end of some wires temporarily until you find the bias where you like and then measure the resistance of them and replace them with fixed resistors.. Sound like a 5150? not so much..
Aharon
Has thanked: 24 times
Been thanked: 5 times
Post by Aharon »
Your day definitely has more than 24hrs :applause:
okgb
Has thanked: 222 times
Been thanked: 38 times
Post by okgb »
Anyone compared this to the wampler SLOtortion ? [ or any other fet emulations ? ]
any pcb's available ?
[ Yes I too am dying to hear try -build -one ]
mozwell
my favorite amplifier: home made SVT2
Completed builds: baja tube driver, several TS variants, Sansamp GT2, Ross Comp
Has thanked: 22 times
Been thanked: 66 times
Post by mozwell »
found this somewhere, its the same basic sch, but with some changes done
SLO 100 FET version from GT labs_.pdf
(1.41 MiB) Downloaded 368 times
zilla
Post by zilla »
Aharon wrote:Your day definitely has more than 24hrs :applause:
elkulon
Has thanked: 17 times
Post by elkulon »
Nice...
I've built the Freya from Soulsonic... Nice work from Chittum, It sounds killer.
It has 7 knobs, one more than this, the 7th would be a Depth control...
J0K3RX
Post by J0K3RX »
elkulon wrote:Nice...
Nice!!! I was seriously gonna build that one!! I was curious about that tone stack too! You have any pics or sound samples of that? You are a man after my own heart..! :wink:
