Help with which way componets go onto a veroboard
greenblueredblue
Post by greenblueredblue »
Hi
I am a serious noob and am just about to embark on my first project. I have noticed that on the veroboard layouts some of the components are writen up or down as you can see in the pic and i was wondering what is the difference and which way is which. im guessing one is possitive and the other negative and if this is the case which end is which.
greenblue
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
greenblue
Some components are polarised, and have to be place in the right orientation.
Most are non-polarised, and therefore it doesn't matter which way they go.
Usually (hopefully) the direction is noted if it matters on a layout, but the way the component number is marked is irrelevant.
The 2 capacitors shown in your example are non-polarised and can go in either direction.
greenblueredblue
thank you i was getting worried really didn't want to screw it all up straight away.
