Building a 5 knob fuzz factory type clone question.
harry haggis
Post by harry haggis »
Hi there,
I just received my PCB for building this fuzz pedal:
http://www.musikding.de/product_info.ph ... z-kit.html
and I have sourced all the parts listed here:
http://diy.musikding.de/images/stories/ ... ybomen.pdf
but folli9wng this wiring layout diagram:
http://diy.musikding.de/images/stories/ ... rywire.pdf
I can't work out what the blue 3x3 grid thing is and what it's doing? I know it's got soldered contacts on it like some kind of circuit board but what is it's purpose and how would I make one/what am I buying?
I have all the other components to begin making it but just unsure what that part is and what I'm doing with it!
Nocentelli
Has thanked: 1115 times
Been thanked: 939 times
Post by Nocentelli »
iamtherealmungo wrote:I can't work out what the blue 3x3 grid thing is and what it's doing? I know it's got soldered contacts on it like some kind of circuit board but what is it's purpose and how would I make one/what am I buying?
That's the footswitch - It's a 3PDT (three Pole, double Throw) which is standard for true bypass with an LED to indicate on/off.
