Any ideas appreciated.
Wanting to build an speaker box for 100watt bass amp head
- telecaster
I found some cool ideas from this site when I built my cabinets.
http://www.colomar.com/Shavano/construction.html
KindaFuzzy - Looks like a blue nail polish and nutella sandwich.
Freekish - "Our originality is in the basement. Our business is in the toilet"
Guitarlcarl - I did take offence at being called an idiot by a moron.
- deltafred
- Opamp Operator
I've just completed a fEARful bass cab, but they are not only for bass, they do equally well with keyboards, drums and PA.
http://greenboy.us/fEARful/
Not cheap but worth the cost in my opinion. They use either the Eminence 3012LF or 3015LF 12" or 15" bass speaker plus a choice of 2 mid drivers with optional tweeters, probably needed for keyboards.
Pretty keen to build the box myself with help from an experienced woodworking friend.
I was thinking about building a column cabinet with a 15 at the bottom, 12 in the middle and 10 at the top. Or it could be 12" + 10" + 8".
I haven't checked how many ohms the head puts out but you can wire them to get the desired result yes? no?
- deltafred
- Opamp Operator
Not usually a good idea mixing speaker sizes unless you have them working different frequency bands, woofer, mid, tweeter, then you need a well designed crossover.wolfy wrote:Pretty keen to build the box myself with help from an experienced woodworking friend.
There is a lot more to speaker cabinets than building a box and fitting speakers in it. Yes it will make noises and you can probably wire the speakers in such a way that you do not damage the amp but if you want it to sound good then it needs to be designed around the speaker/s you are using. Google Thiele Small parameters.
On the Eminence website they have suggested enclosures details for their speakers. That is a very good starting point.
