I have traced this one from a custom fuzz/boost (still figuring out the fuzz part, it seems a bit odd), but i am pretty confident that the boost circuit is the the same one he uses in the nuke booster. As you can see, it's a SHO ripoff. I couldn't get the values of the input and output capacitors (my bud didn't allowed me to dissect it, and i don't blame him since he paid 250 euros for this shit) but the input capacitor is a small ceramic disc, probably a low value one since it's a treble booster. This cap is probably subbed for a bigger one in the original nuke booster, since this last one is marketed as a "transparent booster". The output capacitor is a big box type cap, so i think this is a more standard value like 1uF or so. Enjoy:
T-Pedals - Nuke booster
- Cannibal
My first contribution, i hope you like it
- Nuke Booster.bmp (1.12 MiB) Viewed 1195 times
Seiche wrote:there's a difference between being drugged (I don't think it was only booze) and retarded.
- RnFR
no resistor from base to ground as in the SHO?
- Cannibal
Just rechecked my drawings: the schematics above is correct, no resistor to ground on the gate.
- culturejam
That's what I was thinking.RnFR wrote:no resistor from base to ground as in the SHO?
- mmolteratx
- Degoop Doctor
So is any MOSFET booster now considered an SHO rip off?
- culturejam
This one doesn't even crackle.mmolteratx wrote:So is any MOSFET booster now considered an SHO rip off?
- Cannibal
This one has the same 10M resistor (and not a more common value like 1M), the same zener as a protection diode, the same collector resistor and probably the same output cap value (not really sure about the input). That's a typical clone + bredboard work, if you ask me.
- coldcraft
or typical parts in any common source mosfet gain stage.Cannibal wrote:This one has the same 10M resistor (and not a more common value like 1M), the same zener as a protection diode, the same collector resistor and probably the same output cap value (not really sure about the input). That's a typical clone + bredboard work, if you ask me.
- Cannibal
all right, maybe i was a little bit to drastic about this one, but hey, i'm here to learn.coldcraft wrote:or typical parts in any common source mosfet gain stage.Cannibal wrote:This one has the same 10M resistor (and not a more common value like 1M), the same zener as a protection diode, the same collector resistor and probably the same output cap value (not really sure about the input). That's a typical clone + bredboard work, if you ask me.
