The PCB Drill Topic
Hi guys,
Did some search and found no answers so I’m opening a topic, sorry if the info is out there.
I’d love to know your recommendations on tools you use to drill the pcbs. Is there any specific tool I can get?
I’ve been using drills intended for other uses, as I’ve been doing mainly fuzzes this was ok, but when you have more than a couple dozen holes, this is a real pain. I mean, for a rangemaster I could even do it by hand, but for a Memory Man? No way!!. So I’m sure there’s PCB drills out there, but have no experience so I’d love to spoil your know how
What do you use? Where can I buy it?...
- mysticwhiskey
For the past few years I've been using a standard mid-size drill press with 0.8mm bits with no problems. I've recently started using a Dremel with the drill press accessory, which results in cleaner holes - probably due to the higher speed of the Dremel which matches that required by the small bits.
- RnFR
yeah, the dremel withe the mini press works well. larger drill presses work fine as well though, and you can drill enclosures.
- lolbou
+1 for this.RnFR wrote:yeah, the dremel withe the mini press works well.
I wouldn't consider using mine for PCBs. But definitely does the job for enclosures.RnFR wrote: larger drill presses work fine as well though, and you can drill enclosures.
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- Duckman
- Opamp Operator
+1. I use something similar to the picture with total successRnFR wrote: larger drill presses work fine as well though, and you can drill enclosures.
- KW1500407.jpg (6.07 KiB) Viewed 2735 times
Thanks pals, I think I'll get myself a dremel, I got a big drill that's good for boxes, but a pain in the back (literal) for pcbs.
Hi, if anybody cares, I got the dremel and… total success. So recommended as a lightweight and space saving solution
