Peavey 5150 ii SGR Replacement Help
metalfan1212
Post by metalfan1212 »
I had a tube fail and fry a screen grid resistor in my 5150 ll. I've already ordered the new sgr's 470ohm/5watt and want to replace them all. I'm pretty good with electronics, soldering etc. but I'm not sure of the location of the resistors. I'm a complete noob at schematics but I really want to do this myself so I can learn along the way. I'm aware of the potential danger present without draining the juice. I know I can do it with some assistance. I also want to add a choke as well. Anyone care to guide me in the right direction? Thanks a ton in advance.
metalfan1212
Nevermind about the SGR's. I found them today hiding under the board. I would still appreciate some assistance with the choke though. Which resistor does the choke replace?
blackbunny
my favorite amplifier: Fender Blackface
Completed builds: Lots of mods to lots of pedals
Has thanked: 271 times
Been thanked: 105 times
Post by blackbunny »
The choke replaces the 400 ohm 10 watt ceramic resistor, R210 on the 5150 PCB. May be a different number on the 5150 Mk2.
phatt
Been thanked: 338 times
Post by phatt »
You say you had a tube fail and fry a screen resistor.
(I'll assume you mean power tube)
Humm,,, My guess is the Amp has issues ,,, likely due to a design flaw.
IMO,,,Not the kind of Amplifier you want to learn from as it could turn into an $expensive$ learning curve. :blackeye
Phil.
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
Just be careful to completely discharge the power supply filter caps before you do any work on the amp, otherwise you could be risking death by electrocution.... :thumbsup
