Transistors in parallel + simulating leakage
polifemo
Been thanked: 5 times
Post by polifemo »
I'm new to Fuzz design but I've been doing a lot of reading lately and a couple of days ago I came across the idea of connecting Silicon transistors in parallel in order to reduce gain (often needed as silicon trannies are way hotter than the germanium ones).
I've bought a PEAK atlas DCA55 component analyzer that takes readings of HFE (+ many other things) but when I solder two transistors together I still get half the same HFE measurement instead of half the gain, which was what I expected...
I've also heard about simulating the leakage - from collector to base - in GE trannies by connecting a large resistor from collector to base on a silicon transistor but when doing so I don't get an reading of leakage as it remains at "Zero".
Something DOES happen though!
Gain now have dropped from about 330 (BC547B transistor) to 7 !?...
And what seems even stranger, collector and emitter have now "switched places" according to my component analyzer !?...
Will these things: "transistor in parallel/half the gain" and "leakage resistor" work differently IN a circuit?
Someone please explain :-)
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
polifemo wrote:Hi,
When you connect a large value resistor from a Silicon Transistor's Collector to it's Base, the resistor biases the transistor "on" by diverting some of the current from it's Collector to it's base... :hmmm:
Silicon Transistors typically exhibit leakage-currents in the order of Nano-Amps, one Nano is one one-thousandth of a Micro-Amp, Germanium Transistors typically exhibit leakage-currents in the order of Micro-Amps, so the Leakage Current is about a thousand times greater than for Silicon Transistors.... :hmmm:
polifemo
Post by polifemo »
In my initial post the word "Half" was misplaced due to a cut n´paste procedure....
"I've bought a PEAK atlas DCA55 component analyzer that takes readings of HFE (+ many other things) but when I solder two transistors together I still get ( half) the same HFE measurement instead of half the gain, which was what I expected..."
I meant that I get THE SAME READING!
My component analyzer do not display any leakage at all when soldering a 1 meg transistor from collector to base.
Maybe I should try a really small one?
I´ll be able to test IN a circuit when some new compnents have arrived :D
Post by DrNomis »
polifemo wrote:In my initial post the word "Half" was misplaced due to a cut n´paste procedure....
HFE is basically the same as a Transistor's gain, what you are actually measuring is the Transistor's "Current-Gain" (assuming it's a Bi-Polar Transistor), that is, how much larger the Collector-Current is compared to the current flowing into the Base of the transistor, say for example the HFE of the transistor is 200, if we apply a current of 1 micro-amp to the transistor's base, we would have 200 micro-amps Collector-Current, another name for a Transistor's Current-Gain that's commonly used is "Beta".... :thumbsup
The Collector-Current of a Bi-Polar Transistor is calculated using the following Mathematical Formula:
Note:
Ic = Collector Current.
Ib = Base Current.
B = Beta, or HFE (Current Gain).
Ic = Ib X B
Try changing the 1M resistor to a lower value resistor, say 100k, or maybe 220k.... :thumbsup
