Colorsound - Supaphaze  [schematic]
alteredsounds
Post by alteredsounds »
gutshots
All inside a big old Colorsound wah case, 8 CA3094S.
s.r.v.
Post by s.r.v. »
thats really cool man. is it yours?
what kind of metal can IC's are those?
IC´s are CA 3094 .... as written. The same like in the small-stone phasers.
The only sad thing:
No picture from the solder/track side.... :cry:
alteredsounds
Sorry, didnt have time to take it apart to do the solder side yet. Some of these old pedals also have become fragile and if it looks like it may break then I wont take it fully apart. I will look at this one later.
R.G.
Been thanked: 39 times
Post by R.G. »
It's easy enough to guess the circuit close enough from the top side.
The CA3094 is a CA3080 OTA plus a darlington transistor buffer in one package. It's essentially half of an LM13700 or CA3280. The OTAs are almost certainly in the same OTA phaser circuits as the ca3094 version of the Small Stone.
From the colors of the auxillary parts, six of them are phase stages (all identical) and two are used in a Small-Stone-like LFO. The transistors probably do the input buffering, output mix/buffer, and maybe an active power filter stage. That is, it's a Small Stone with two more phase stages, a three-notch instead of a two-notch.
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
IS THERE CHANCE FOR TRACE SIDE?
Boris
https://www.diystompboxes.com/smfforum/ ... ic=43677.0
we are playing the same record as five years ago, over there... :roll:
mictester
Has thanked: 32 times
Been thanked: 825 times
Post by mictester »
modman wrote:https://www.diystompboxes.com/smfforum/ ... ic=43677.0
Back in the 70's I had one of these. The pedal altered the speed of phasing (which seemed like a waste of a pedal to me). It was a very similar circuit to the Small Stone (it might have been a copy, but with extra phase stages). This thing hissed so much it sounded like you were playing under a waterfall!!! It was stolen at a gig and really wasn't missed.
I replaced it with a homebrew 8-stage phaser with three preset sounds selectable with three footswitches. The replacement served me well until I gave it to my nephew last year.
niva
Post by niva »
Hello!
I have a Colorsound Supapahaze and it is missing a capacitor (see on the picture below).
Does anyone has the schemartic of it?
Can anyone tell me it's value? And the other 3 as well? Just to make sure
niva
Post by niva »
Here is a picture of the trace side:
BMS1971
Has thanked: 42 times
Been thanked: 31 times
Post by BMS1971 »
anyone did the tracing?
Benoit
