T1M this1smyne Pearl
- jwpartain1
$200 for bad offboard wiring, floating perfboards, and sharpie lettering!
Why am I not selling pedals?
- Hides-His-Eyes
And however many hours of labour...jwpartain1 wrote:$200 for bad offboard wiring, floating perfboards, and sharpie lettering!
Anyway, answer: you're not on TGP's "great guy" list
- culturejam
- lolbou
Considering the whole wiring mess, an hour is way enough I'm afraid.Hides-His-Eyes wrote:And however many hours of labour...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- Hides-His-Eyes
If you can build that in an hour you've no excuse for not making a killing selling dirtboxes
- LaceSensor
Add insult to injury its not even a semblence of something original, its just a Menatone (clone of a clone of a....etc)
- culturejam
Juicy!LaceSensor wrote:Add insult to injury its not even a semblence of something original, its just a Menatone (clone of a clone of a....etc)
How did you figure that out? Or is it common knowledge (i.e. - from the builder)?
- Cannibal
Straight from the horse's mouth:culturejam wrote:Juicy!LaceSensor wrote:Add insult to injury its not even a semblence of something original, its just a Menatone (clone of a clone of a....etc)
at the beginning of the video
Seiche wrote:there's a difference between being drugged (I don't think it was only booze) and retarded.
- drbob1
T1M does have a good rep on TGP most of the time, although he has done some "take the money in advance and deliver in 2 years" kind of deals that have gotten him into hot water lately. That said, I can wire better than that and I'm a hack! How did he get a good rep with that? Also, where are the diodes?
- LaceSensor
~Diodes look to be floating in a sea of hot glue gun spunk...drbob1 wrote:T1M does have a good rep on TGP most of the time, although he has done some "take the money in advance and deliver in 2 years" kind of deals that have gotten him into hot water lately. That said, I can wire better than that and I'm a hack! How did he get a good rep with that? Also, where are the diodes?
I mean fair play to the guy if he can make a living shitting those out but I would not be proud of my product if it look like that.
Would it kill him to use a $0.05 nylon standoff or something?
Im passionate about NOT having hot glue anywhere in a pedal, I think it looks disgraceful.
- culturejam
LaceSensor wrote:I mean fair play to the guy if he can make a living shitting those out
I wonder if there is a reason* that there are a couple 1/2-watt resistors on those boards?
* And by that I mean a functional reason, not just because they were cheap or handy.
- Ice-9
It's just an expensive pile of badly build clone.
- LaceSensor
Id estimate absolutely NO functional reason, probably a misorder or cheap.culturejam wrote:LaceSensor wrote:I mean fair play to the guy if he can make a living shitting those out![]()
I wonder if there is a reason* that there are a couple 1/2-watt resistors on those boards?![]()
I have a bunch of ...I think 220k in 1/2 watt from when I was just starting, try to slip them onto vero builds when I can
- candletears7
I've dealt with Dan in the past, and he has always been prompt, friendly and professional. He was awesome with me in a deal with some non working pedals, so for that I give him points. I know he has been copping a hiding on TGP of late regarding delays in getting products to customers, but till then he was one of the preferred "Go to" guys over there.
I believe that he has always been upfront about what the Pearl was, and most people on TGP knew it was a Snapper and Blue Collar in a box. It's up to the individual to choose if they want Brian Mena's original pedals, or T1Myne's combo version. But the Snapper is a tweaked OD-1, so what do ya do? Personally I believe in supporting the original builder. However, the pictures do speak loud and clear. I would be getting some PCB's made up, some PCB mount pots, minimise the wiring and clean up what needs to be there, and put some time and $$$ into a pro looking decal.
- Hides-His-Eyes
He offers each side individually too.
- culturejam
So then, you recommend buying Boss?candletears7 wrote: most people on TGP knew it was a Snapper and Blue Collar in a box. .... But the Snapper is a tweaked OD-1 .... I believe in supporting the original builder.
- Seiche
that is not allowed on tgpculturejam wrote:So then, you recommend buying Boss?candletears7 wrote: most people on TGP knew it was a Snapper and Blue Collar in a box. .... But the Snapper is a tweaked OD-1 .... I believe in supporting the original builder.
