Hey all,
This is my first post and I'm sorry if this question has been answered a hundred times before. I tried practicing soldering last night and I couldn't get the perfboard hot enough to melt the solder. How hot does the iron have to be? I think I had it at thirty watts. May have been 20 though.
Soldering Iron: How hot?
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
greaserrock wrote:Hey all,
I've got a Temperature Controlled 35 Watt Soldering Iron which I usually keep set to about 350 degrees C, you want to have the iron a bit hotter than the melting point of standard 60/40 rosin-core solder, which is about 280 degrees C, the extra 70 degrees is needed because the copper tracks and component lead acts a bit like a Heatsink, when making a solder joint, it should take about 5 seconds to complete, about two to heat both the copper track and component lead, one to apply the solder, and two more seconds for the joint to cool down....
You could try investing in a 48Watt Termperature-Controlled Soldering Station, providing that you've got your soldering technique sorted, you can produce consistently good joints....
As a side note, the melting-point of solder is controlled by the relative percentages of Tin and Lead that is in the Solder, the higher the proportion of lead, the longer the solder remains in a plastic state before it solidifies, so standard Electronic Resin-Cored Solder has 40% Lead, and 60% Tin and therefore solidifies quickly from a liquid form without staying in a plastic state for very long, Plumber's Solder has a different ratio of Lead to Tin and stays in a plastic state longer before solidifying...
Thank you for such a quick reply DrNomis! I'll try turning it up a bit. I think the settings on my iron go up to 50 or 55. (Can't check right now cause I'm at work). Thanks for all the specifics on temperature and technique. I'll try again tonight. I love this board!
