Need help with change value of capacitor in tone control
Posted: 13 Jan 2012, 14:15
by login721
Hello i making a TubeScreamer TS808 clone.
In the original schematic they use 2 0.22uF Tantalum capacitors, but i don't have them, so i replace with 0.22uF Mylar capacitors.The result is when i turn the ton pot up, i get noise and loud hiss.
Can i replace the 0.22uF Tantalum with 1uF Tantalum then change the value of some resistors to make the tone pot work ?This is the original schematic of tone part and my modified version .I not tested it yet because i have to order parts to build it.Can you please check it for me ? Thanks .I just want to change the c1 and c2 from 0.22uF to 1uF(witch i can buy in my country).
Sorry for my bad English.
Re: Need help with change value of capacitor in tone control
Posted: 20 Jan 2012, 22:50
by Mr.Grumpy
The mylar caps should sound as good or *better* than the tantalum caps. So I don't think your problem (noise and hiss) was caused by substituting mylar caps for tantalum caps. Almost any overdrive pedal will have some hiss and noise if the gain and treble are turned up.
Posted: 16 Feb 2012, 14:31
by looperstar
Could it be that you are looking to buy 0.22uF capacitors which is the same as 220n. Most suppliers I use would call it a 220n capacitor so it is possible that if you search for 220n you will find what you really need. 1uF is a massive difference to 220n and would sound totally different.
Hope this is of help.
Posted: 16 Feb 2012, 15:27
by JakeAC5253
Try putting a 4k7 resistor across the outer connections of the tone pot and see if that makes the sweep much smoother.
