Hi, Im new to the forum, and soldering on PCBs. Is this what lifted trace means, or do I just need to use different solder --(with flux in it?)-- that will stick to the board again? I was using regular electrical 60/40 solder with an adjustable iron @ about 35 watts. Instead of solder flowing around the lead, it started coming off. When I tried to re-form a pool/pad of solder, it wouldn't stick to the PCB???
I just need a pad of solder right there so I can stick a lead in it. Tell me there's something I can do, I was almost done!
