Wampler PlexiDrive offboard wiring
I'm planning on building Wampler PlexiDrive but can't figure out how one would wire this with the input/ouput and power supply. I'm planning on using the offboard wiring mentioned here. I found a picture of another member who build a PlexiDrive. In the picture I see 4 wires which need to be connected to other parts. Which parts would this be and what else has to be connected using wires? I'm planning on using both a battery and 9 volt adaptor. You're help is greatly appreciated!
I got a little further with help from this great site. In the picture previously mentioned the far left blue wire needs to be connected to pin 1 from the 3PDT. The blue wire from the volume pot needs to be connected to pin 3 from the 3DPT. Is this correct? The red wire goes to the DC supply and the black to the sleeve of the output jack right?
