MINI Speakers??
- sinner
- Has thanked: 1031 times
- Been thanked: 907 times
I've build a nice sounding solid state mini amp for son of my bud with speaker taken out of an old, broken iMac.
Highly recommended
Highly recommended
skylark44 wrote:Check out this link to Futurlec http://www.futurlec.com/Speakers.shtml ...I believe it might just be what you're looking for. Good luck with your build!
Thanks, forgot about that site, the 1W and 3W round ones might be perfect, I have similar ones that I ripped out of an old toy keyboard, if I can find something with those dimensions/power ratings but better quality I would be a happy camper
- rocklander
- Has thanked: 1404 times
- Been thanked: 227 times
- Contact:
lotsa lil holes + bastard file?
- skylark44
How 'bout a small hole saw (for your drill)? You can usually find 'em at Big Lots, or Lowes, Home Depot, etc. (they usually come in a "kit", with a few different sizes)...and they're pretty cheap too
- Seiche
yeah I figured this was the way to go. But does this actually work well on aluminium? I've only ever used it for woodwork.skylark44 wrote:How 'bout a small hole saw (for your drill)? You can usually find 'em at Big Lots, or Lowes, Home Depot, etc. (they usually come in a "kit", with a few different sizes)...and they're pretty cheap too.
my drill machine will probably quit with one of those. It's pretty cheap and sucks. I can barely drill holes in a line with it.
- PokeyPete
–Hunter S. Thompson
–Hunter S. Thompson
- skylark44
I've also used a plastic box, on a few pedal projects...using my Dremel, to make the holes. Start out with a small drillbit, then carefully enlarge it with a cone-shaped stone bit (I marked the stone bit with a Sharpie, to avoid over-enlarging it
