Marshall Guv'nor Issues
greenblueredblue
Post by greenblueredblue »
Hey
I'm currently making the guv'nor from the layout below. I'm very new to this and i noticed that neither C7: 10uf or the D1/D2: LED's state which end is positive and negative and was wondering if it isn't mentioned does it matter which way it goes in.
any help would be awesome so i can get this build finished.
Duckman
Has thanked: 320 times
Post by Duckman »
greenblueredblue wrote:C7: 10uf or the D1/D2: LED's state which end is positive and negative and was wondering if it isn't mentioned does it matter which way it goes in.
The little dark zone is your negative pin in C7 and the line in D1 and D2 are also the negative.
When you're placing polarized components in DIYLC, your first click establish you POSITIVE pin, hence, your second click, your NEGATIVE pin. Remember that.
greenblueredblue
