Need help with wiring
Dominik1986
Post by Dominik1986 »
Hey guys,
I am fairly new here and got a question for you. I would like to wire two inputs to two different outputs and would like to switch between them with a 3PDT switch. Here's how I would do it:
I would wire it like an A/B selector but instead of one input I am using 2. I would wire the two inputs to the 3PDT switch as I would do it as if I have one input. Is this right?
Kind regards and many thanks,
Dominik
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
I don't know if that input thing would work or if you'd get hum, etc.
but assuming it does, you only need a SPST Switch like this
middle would go to the inputs, left to one output and right to the other.
